This is what happens when you are boob and don't openly the throttle on a compression test.
Won't make that mistake again. This is our compression after the warm up on our 3 startup.
Awesome vids dude! I wish i get the opportunity to be a dad of your caliber. Sweet.
btw, plugs on my 200 are a bit black-ish (wet).
running .95 mains (stock), pods, and the needle is in the 4th position from below (lean). Also, it does not respond to throttle when it's more then halfway open. bogs a bit. i've done a lot of adjustments with other mains, needle heights and stuff, but this is the best we can get her, and its not good enough. She wont go above 70 km/h aswell. Timing is spot on, runs the moment the button is pushed (cold also), valves are ok, compression is around 120 (just like yours) carbs are cleaned again and again and again.
I found that one intake rubber leaked a bit so i fixed that. Before that she ran crap, would not idle well and such. Now she runs strong and good, but wont go above 70 and bogs if you try to get her to go faster. any ideas?
at first i thought it was lean, because of the symtomps (pods, no power in upper area) but plugs are covered in black and with bigger mains to 100 she runs even crappier.
Thanks right back to the two of you for sharing the adventure with all of us :) I'll explore ways to try and capture the thread so it can be somehow stored / backed up etc. but rest assured, as long as I'm alive, and people want DO THE TON online, it will be. I figure I've got around 40 years left in me so there you go.
You are most welcome young man. It's been my pleasure to play a tiny role and to watch this project develop and to see you learning all those new skills. Stay safe and keep having fun.
took her out on a country road last night to break her in a bit. We are running 102.5 jets now...Uni long filters, 18mm keihins, open cl exhaust. Ran real well surprisingly no flat spots. The plugs were bronze before the ride. Thanks Bert!
kopcicle said:
You are so very welcome . What's next ? ;D
~kop
His long term goal is to be a tuner for a motorcycle team...so we build another. We have been approached by a guy who has a 71 BSA rocket 3 with a big bore kit that has been sitting for 14 years in his garage. The local Norton BSA group needs a sponge. Another guy has a 75-750 gt police water buffalo in storage.
His sister wants us to build her one. Momma wants one. We have a friend who has a 175 that he has been saving for a build. I think we will build a 175...repetition, repetition, repetition...
I know Lucky loves him...she revved all by herself when he approached her when she was warming up last night...
I was on a plane to Seattle this past weekend and met a gal sitting next to me-Britney. Her husband Steve is the turner for Big D's race bikes and loves to go to Bonneville...the short term goal has always been to Do The Ton! He is working on his form.
thanks Tim!
95 mains are not stock for a cb200.. 88s are. I was having very similar problems with my 200 because I didnt know that the PO rebuilt the carbs with larger jets in every circuit than stock requirements ask for. I would just return the carb configuration to the stock settings:
- 88mains
-38 slow/pilot jets
- needle clip in middle or 3rd position
Then go by the manual and sync the throttle cap screws, and set the idle and air mixture screws. If you do all that and still have problems than you will know it isnt a fuel delivery problem in the carbs.
This is just my 2cents from experience, there are many fellas on here with much more wisdom than I. Best of luck brother. 8)
R3 is an awesome bike and is much faster than one might imagine. I built one for a basket case many years ago.
GT750 is a big fat lazy bike that weighs over 500 pounds and with a little attention to detail can be made into a nice road burner. Stock motor make somewhere around 48-54HP at the rear wheel. Mine is at 76hp and 71 foot pounds of torque on stock carbs and weighs a touch over 400 now. Almost anything is possible.
Now this...this, I've gotta see.
It was BOTM a few months ago I believe Phat Trakka
Feb 2012 tied for BOTM
http://www.dotheton.com/forum/index.php?topic=33566.0
lol the only lady you can call and name...and get better performance
http://youtu.be/nM8uRndlZIA
http://www.dotheton.com/forum/index.php?topic=22894.0
HOLY LORD
HOLY LORD
amen brother...thanks for the link all the photos were removed on Botm can't wait to show my son
I'd show you the dyno charts and porting specs but then I'd have to kill you :-)
I corrected the missing/broken links.
[end threadjack]
