I am thinking those stacks are going to be hard to fit unless you have an extender because that center frame is fat. But I bet you had already noticed that.
there are a few ways to make those fit.... they will fit with some mods to this frame and they will really fit in a cb160 sloper frame...:) with a vertical motor...thanks Teazer that is a 10lbs savings...and it puts the carbs at the correct angle :)
Sonreir said:
Only if they're small diameter. You want thin wheels with larger diameters.
now for the salt we may want to go the other direction. Kop has us looking smaller with different gearing. If Kop ran Bonneville I think he would do it with style like Rollie did. Rollie gave a 13 year old a secret back in the 50's to help him set a record.
http://www.bonhams.com/auctions/19466/lot/316/
http://42ndblackwatch1881.wordpress.com/2009/06/06/live-fast-die-free-roland-rollie-frees-1948-world-speed-record/
According to what I have read about running on the salt it is like running on wet pavement.
You might want to look at RS125 wheels and slicks to reduce rolling resistance - or alloy rims and a drag race front slick and RS125 rear or or RS125 front on the rear on say Marchesini rims - not budget priced by soooo sexy and light. First time I was handed a Marchesini box I was sure it was empty and that someone stole the wheel.
Magnesium is the way to go if cost is no object. You could also look around for some 125 racer's takeoffs and use alloy 17" rims on your hubs for a cheaper solution.
The pit crew adding the Teazer Tail td-1 airtech! It is perfect! Prepping for the Peel 1 fairing.
Lets try again
Texasstar said:
"80MPH on a cb200 is not good enough"
"iridium plugs"
80mph on that? Are you the one in the pic??? Texasstar, you're no small dude. That is an awesome feat you've accomplished! Let me pilot that thing and it won't even know somebody's aboard.
Uh, you do have a steering-damper, correct?
Also, iridium plugs? Off the top of my head I'm going to guess BR8IEX? Anyway, if they do have an "R" in the designation and it's an NGK, that means resistor... Are you running those with resistor boots as well?
Those wheels and brake rotor look hella heavy ;)
The boys removed our tach, speedometer, cables, headlight and hardware, mocked up the fairing and the seat.
We shortened and lowered our clip ons (we may need to address the offset.)
We will need to shorten our clutch and brake levers
Raise the travel of the forks or go to 17" wheels
We can move the seat behind the shocks with no problem.
Yes that is all 215lbs of me! We need a steering damper, we are running non resister boots...and I will need to take up yoga! Lol
Sonreir said:
Weight doesn't affect top speed; only acceleration.
I don't know if you've met Texasstar, but there is no way he can actually lay down on that bike, HAH.
I had aerodynamics in mind, but completely forgot that his next run will be with a fairing...
never say never lol
Seat moved back and we solved the offset issue with the fairing. Thanks to Perraults clip-ons we are changing the sides of the clipons and the clipons will now give us an offset forward. The great thing about Rick's clip ons are they are so adjustable. The brake and clutch levers can be mounted on the inside of the offset. Before and after.
Don't know what racing organization rules you'll be running the bike under, but I think the tail end of the seat extends too far back after the 6" aft relocation. Not saying it does for sure - just suggesting you check the rulebook...
I was at Daytona in '84 and saw a Yam fail tech 'cause the bodywork didn't meet the rules. As I recall, the seat was too long, too high and the fairing may have been too far forward as well (didn't meet AMA rules for 250 lightweight).
It'd be a pity to put in as much time and money as you have in your project and not be able to run the bike.
Pat
Why are the clip ons upside down? ie they are on the wrong sides. Why are they at such different heights too - is that because the hand pods are different left to right, or just an "in process" shot?
The good thing with those clipons is that they are adjustable - the bad thing is that they are too wide. Try some that have teh bar closer to teh fork leg - steel are good for that.
