Keihin define "size: by slide diameter and Mikuni has a round bore and that is the "size". that means that a 20mm Mikuni will have a 20mm bore and 22-23mm slide.
Keihin uses a figure 8 bore so that at low throttle openings, it's basically a smaller diameter carb so gas velocity is high. When the throttle is all the way open the bore is elongated to be equivalent of a larger size. Very clever - almost a variable bore carb. And that was how they calculated the "size" it is the nominal equivalent diameter.
CB200 has a taller oval than a 175 and that's why it's rated as a "20"
Keihin also had a reputation for not "tracking" as well as Mikuni. What that means is that the overlap between circuits was harder to fine tune and they were harder to get smooth all the way through the rev/throttle range.
