pacomotorstuff said:
Don't know what racing organization rules you'll be running the bike under, but I think the tail end of the seat extends too far back after the 6" aft relocation. Not saying it does for sure - just suggesting you check the rulebook...
I was at Daytona in '84 and saw a Yam fail tech 'cause the bodywork didn't meet the rules. As I recall, the seat was too long, too high and the fairing may have been too far forward as well (didn't meet AMA rules for 250 lightweight).
It'd be a pity to put in as much time and money as you have in your project and not be able to run the bike.
Pat
Pat we really appreciate DTT and everyone like you who are watching our back! Currently they are no rules as our first goal is to Do The Ton. We are going to play with the tail to see where we get the best results. Zeke needs to go to CMRA racing school before he can road race and then we will pay attention to the rules. The second goal is to do our personal best at Bonneville BUB in two years. Next year we plan on going to BUB to do a dry run...however this year it looked like BUB got a lot of rain.
This time is priceless and worth every penny...
teazer said:
Why are the clip ons upside down? ie they are on the wrong sides. Why are they at such different heights too - is that because the hand pods are different left to right, or just an "in process" shot?
The good thing with those clipons is that they are adjustable - the bad thing is that they are too wide. Try some that have teh bar closer to teh fork leg - steel are good for that.
my wife said the same thing...yes in process. I will post a better picture tonight we are flipping the clipons so the offset can be used to push the bars forward giving us more length and room. If your look at the right clipon and envision it on the left side this is what it will look like...they are upside down because the boys put them on wrong...
Id pay close attention to how you mount the fairing with the forks lowered in the tree. Since the forks sag a bit when you sit on the bike, they'll be in a different place. I have the 200 fork and tree on my 175, with heavier Racetech springs.
If you need to go back up in the tree the fairing may be off and look off a little. I had mine lowered and decided to reset them when I was calibrating my fairing's position due to my 200lb rider weight.
Now that I've ridden the bike, I didn't like the trail they gave me under braking so back up they went...
I think you are right. We are going to go back to stock height. Then once the engine is back in we are going to zip tie the fairing in place to see how she runs under load.
did you mount a steering stabilizer and if so which one?
I used an NHK stabilizer. Now that i think of it-- I used my 175 lower tree, which had the mount cast into the assembly. I'm not sure if the 200 has one.
I may buy a clamp to attach it to the fork tube instead of the mounting hole. I'd rather have it accessible to my left hand while riding.
...Doesn't look like I have a good picture of the whole thing.
you bike is total class...how is she running?
Had some technical difficulties...
The O-rings around the oil passages between the cylinders and the head were leaking so I pulled it apart to apply some sealant to the locators and install some thicker O-rings.
Since it was apart I also switched to another stator I had laying around.
The tack needle fell off so I had to disassemble that and put it back.
Balanced the tires again after discovering they weren't *quite* seated properly.
Switched out some nuts for nylock nuts... and I've also got some new jets and plugs on their way.
Still have to paint the 1-1 exhaust. Id like to finish my 2-1 while I can still weld with the garage door open.
But you cant buy back time. :)
We flipped the clip ons and now the offset is forward and we have full range of motion we also are now back to stock height.
ordered the NHK steering stabilizer for our cb200! Thank you!
Found something you folks might be interested in.
http://lincoln.craigslist.org/mcy/4044491989.html
The Missezzz has beec doodling
Interesting that you had to cut the left side of the frame. I put a small notch in the right side for the bowls of the keihins to clear.
I'm guessing that yours are flange mounted and not of the spigot type?
we cut both sides...now any carb and velocity stack will fit.
What is the history of that crest and the expression - I struggle and emerge? It appears to relate to the Dutch history of pushing back the sea but I don't speak Dutch and google translate butchers things.
yes it is about the Dutch rolling back the sea. Doing the seemingly impossible. They had grit! Has great significance on many levels for our family and Lucky. Lucky is metaphor for life. It is more than Pirsigs metaphysical journey for me personally. You can be told things all you life...oh you are slow, why don't you fall into the ranks of what you were designed for, and be cast aside in the dump, but one day a little boy takes you home and changes all that...Luctor Et Emergo "i struggle and emerge" (with a little help from the right friends) I tell my kids that can't is a four letter dirty word.
