cafe mike said:
I'm personally sitting on the edge of my seat. I have changed my thought process. Your greatest power made is with a longer tube on one cyl. Your letting the exhaust length work for you. Sure tuning carbs is differnt. But the wheel leaving the ground. Wth.
The pipes are flying off because they are working. If you can make mid pipes at differnt lengths ( to see what it does when small changes are made)but have them secured via springs or tabs bolting each other. Would that work?
well we discovered the power benefits of the short megaphones very interested to see what happens when we put the long megaphones on.
Then one short megaphone on the long pipe and one long megaphone on the short pipe..just for tinkering sake...gonna ventilate the case first though. We will weld some tabs and springs and then mess with stepping the pipes
that sounds like a plan. 8)
Try and get total length close, you don't need too much bottom end, just abuse the hell out of clutch to get moving plus take spare plates and gaskets ;) .
You will need highest gearing it can pull, the altitude at Bonneville will mean complete re-jetting when you get there
Without some sort of support on the back end, all the weight and vibration is taken by the pipes. The pipes WILL crack and fall off if megga's are not mounted.
I think extending lower pipe so outlet is right at tyre should improve max top end power, my 175 used to lift front wheel around 60mph when changing up although being a 4 speed it never went much over 90
lol that post needs to be quoted "just abuse the the hell out of the clutch" thanks PJ did you ever modify your cam chain tensioner?
Are you thinking a cb350 boretec style tensioner?
Would an extra clutch plate help?
simo! Well we discovered that the cl175 has an extra clutch plate. So we will install that on Zeke's after we lighten the clutch basket. What is interesting is the latest model cb350 has the same tensioner design as the crf250r. We have looked at the ka tensioner and it looks like it is bolted in place of the tensioner wheel. There is an aftermarket tensioner made for the 750 that lookers like it is interesting. I am sure we can come up with a solution for the little 175. Just a matter of a little fabrication. :) and new zeelander give it a try. As Teazer suggested if we remove the pivot and bracket from the cbr600 tensioner we have and pin it like the crf250r all we have to do is come up with the tensioner mod and mount the guide. Probably will get a cb350 guide to look at. The pistons we are using on Zeke's build are 48g lighter than stock 175 pistons. They also have a better ring design. Our goal is to sling 12,500k reliably. We are also using the crf150 valve springs. The great thing is what we do with that one we can do with Lucky.
The clutch inner plate or Plate A I think in Honda Parlance is dished on a 175 and 160 and I cannot remember what's in a 200. It's dished outwards and can be flipped to get more plates in there. There are also different thickness of friction and steel plates so juggle those to get the clutch pack you want.
I just fit an extra steel plate in the middle. Cut some grooves in the 'inner' sides to get oil flowing through it and help cool clutch center when your 'abusing the hell out of it' ;D
'We' (my brother and I) did the same to the 90+mph Honda S90 he had. (change into 4th gear at 75mph :o )
Gearing was so high it would barely get going, massive clutch slipping plus 'paddling' until it hit 10~15 mph
paddling like Fred Flintstone lol!
Ever watch a 125cc road race? We all used to paddle the bike to get off the line. High first gear and no power below about 9500 makes for a painfully slow start.
nothing more painful ...or slow than this http://instagram.com/p/okPYdglk8V/ ;)
crazypj said:
You may need to make a set of rollers to get it going
no doubt! I can start it by hand on the stand rather than pushing it...what gear does the gp class start in?
First gear but gearing is pretty high
It's only MX where you may be using second or third gear for starts (and only if you have enough power so bike doesn't stall)
Well that may be my problem I had it in 3rd push starting. When we start it on the stand it starts real easy in third gear by hand.
Motor is small enough to start in second, it will turn over faster.
If gearing is high enough you may be able to start it easier in first.
one 'trick' is to put bike in gear then roll backwards until it comes up on compression from the wrong direction, means you have at least one rotation before it hits compression again.
It's the only way to get even close when bump starting a 500 single ;)
How much travel does a rear shock need street vs track? What about bonneville?
Depends how rough the surface is.
I would probably have around 3" but set up a bit soft so wheel can 'drop' into 'holes' if necessary
The cheap e-bay Chinese shocks may be a reasonable fitment
