Sonreir said:Top ring is the shiny one. Middle ring is the dull one.
Caf'd Out said:Posting to read later. That garage/living room/man cave room is the tits. That is exactly how I picture my set up later down the road once I'm settled. nice work so far. Interested to see this build from a designer's perspective.
MHDesign said:Thanks! I'm not sure now, but can dig through receipts if you're interested (I didn't order it from any of my regular sources for parts). It was a generic fender that I cut / modified. Essentially a piece of rolled steel with the right diameter.
MGD said:Might be a good time to soak the tank in vinegar before you weld it up.
I see a bit of rust in there.
JustinLonghorn said:I approve of your Pembroke shop supervisor.
MHDesign said:...each is labeled "top" designating which side goes up, but apart from the black-oxide finish on one of the two rings, they look identical to me...(?)
crazypj said:Chrome faced ring is top one.
Nope![]()
anyone e else have some input?el barto said:Can you tell me how wide you went with your rear fender? I've found something similar but good to hear from someone who's already been there!
MHDesign said:New problem: I'm disassembling my gauges to clean them up and replace the faces. My issue is that I can't seem to get the trip-meter reset knob off. I read that it's reverse threaded, but turning in either direction hasn't yielded any results. There is no set-screw. Is it press-fit?![]()
Sonreir said:Isn't the chrome one the shiny one? I thought the cast one was the darker? ???
MHDesign said:Width is 5.25", which I think is more than sufficient. I still have a little trepidation about my travel clearance with my new rear shocks though. They're 1/2" longer than stock (progressive 412 series). They "should" be fine, given that I weigh nothing, but according to install instructions, they might be close to rubbing:
