First Cafe project (CB450)
Doc. said:
Has anybody seen any custom mounts for rearsets without the passenger peg brace? I want to cut it off, but I'm not sure How I could mount custom rear sets. Looking for ideas.
Thanks.
Some people just make triangular brackets and attach them the frame. I think it would look got with some slimer round bar. Just a thought
I like his idea!!! (taken from a build thread here)
schaubster said:
good progress!
Thank you! It's very slow though, compared to everyone else's on here :P. But sucks working 12 hr days and taking classes as well.
If you don't want to weld or don't have a welder, another way would be to bolt this bracket to the passenger tubes by drilling holes in them. Then cutting away the excess tube. The tube stubs would be hidden by the bracket. Also it's better to weld/bolt brackets to the outer tubes to give you more clearance especially on the brake side where the lever peg can hit toothed brake shaft (on CB750's).
Cheers
Cheers
Do you mean like bolt it to the first inch or so of the tube coming off the frame, then cut the remaining off? That also sounds like a great idea. Thanks!!
Sorry guys I know the progress in this thread is super slow, but I finally found a powder coater for a really good price. Let's hope he does good work, lol.
I had a question in the mean time. When I receive my wheels back, I'm planning on putting it back together as soon as possible, and I was wondering is there a trick to respoking the wheels to get it centered righter? For example how would I know how much to tighten each nipple for the hub to be centered?
Edit: So I did some research and found out about trueing the wheels. Would it be safe to take the wheels to a bicycle shop and get it done right? I'm not sure if there's a huge difference between a bicycle wheel and a motorcycle wheel.
I cracked open the engine today. It's ugly :o
On the other hand, the rocker arms and cams and everything up top looks good, so I got lucky there.
I was actually able to figure it out. These have torsion bars instead of springs, so I got them out. Thanks though!
I was able to free up the piston as well. Took some pounding and patience, but it's out.
I never pulled the alternator rotor, but you do need a puller for that. One of those three clawed do-hickies would do the trick.
Oh ok. So it's not threaded on correct? I wasn't sure if it screwed on or just pressed on.
Do you know how to remove the clutch outer cover and the gearing?
