First Cafe project (CB450)
I went to the local motorcycle shop and bought fork oil, something light weight. I think I bought 7 wt. My manual, for the CL 350, called for ATF!
Doc. said:
Also, these are the parts I have decided to powder coat. If there is anything I missed, or you guys recommend I also do while I'm at it, please feel free to share. I want to make sure I get all the right parts powder coated now, than kick myself in the behind later.
Make sure you have your vision/end result hammered out before you powder. There's a couple things I need to grind off along my seat rails (hinges, seat lock) and something I wish I added (rear set mounts, fender bracket). Since I rushed to powder coat it I will have to "touch up" with some semi-gloss spray paint. Not the end of the world but proper planning would have been better...but hey, it's my first build!
Thanks guys.
Yeah I'm still working on the plans. Slowly adding stuff to the powder coat pile. I'm gonna have to test my skills in MS Paint and go through some color combos to see what I like, lol.
Here are some pics. These are the best I could get the tubes to look. It took alot of scrubbing and sanding. I still haven't applied any polish to them. The second picture is a close up of how the rust has eaten in the tubes, and almost impossible to eliminate without grinding metal down.
Lowers are ready to be sent out for powder coat as well.
Totally agree! Do a mock up first with the bike assembled completely first. Then, diassemble and do the painting. You'll be much happier in the end that you did.
Worked on the front wheels a bit today. Well more like the hub and rotor and crap. The rotor will be painted. I'm not sure what I want to do with the hub yet as far as color. It will either be black like the rim, or painted the same color as the tank. Still figuring that out. I cleaned off the hub bolts so they can be reused.
Do you guys think this is salvageable? It's pretty rusted inside :-\
id have a go cleaning it up and decide from there, sometimes im suprised how well things clean up. doesnt look too bad
Are the hub bearings pressed in? I'm looking to replace them (even though they are in good condition), but need to know so I can find a press.
Cut off the unwanted tabs and the back end of the frame today. Going to get the u-bar from DCC to be welded on. Then hopefully finally ready for powder coat.
A little more progress. I've been doing really small petty stuff so nothing really to post about. Also been busy with life.
I pounded out the steering races to be replaced by an All Balls kit. Cut the kickstand off of the peg bar, so I can still use it. Cut the u-bar to the right size, and hopefully (fingers crossed) it will be welded on tomorrow. And lastly, grind and smoothed off the handle bar riser lip thingies, since I'll be using clip-ons.
Looking good man, I want a 450 soo bad. This winter or fall I will be redoing my wheels, and I was wondering how u got the bearings out? thanks excited for u
Thank you!
I used this method
http://www.dotheton.com/forum/index.php?topic=9448.msg83326#msg83326
It was a little pain in the butt because the anchor was a bit smaller than it should've been. If you get one with a diameter close to the bearing hole, it should work well. I still haven't pulled out the rear hub bearings because it's bigger than the front, so I'm going to get a bigger one tomorrow to do that. Hopefully it'll go much smoother, lol.
Doc. said:
Thank you!
I used this method
Yea it looks like that will work perfect, I will definalty do that, unless my dad has some werid gizmo that I dont know about. Good luck with the rear
Thanks. Give it a shot, it's not much so no loss in that.
The back wasn't any easier, until after I got mad and started to pound the inner rim of the bigger bearing, hoping it would separate the bearing and push the other one out. Little did I know, that inner rim is an adapter, and it was MUCH easier to just use a piece of pipe (or a nut on a bolt) to pound that and push out the bearing on the opposite. Took all of 30 seconds, lol.
Has anybody seen any custom mounts for rearsets without the passenger peg brace? I want to cut it off, but I'm not sure How I could mount custom rear sets. Looking for ideas.
Thanks.
