crawdadman said:aesthetics are important, you want to be proud of what you are ridding! But i just realized recently, it is no fun ridding a turd covered in sprinkles...
Rich Ard said:You can soak the boots overnight in xylene - available with the paint strippers at your friendly hardware store. If they are hard but not cracked that should do the trick.
As to your compression test: did you do so before taking the carbs off? Should be done with the throttle wide open, which would have been difficult if the carbs were still on since the throttle doesn't work![]()
surffly said:Hate to rain on the parade, but it might be time to pull the chute and see about getting a different bike that more fits your skill set and goals.
While defiantly not impossible for you to revive this bike the time and expense might not be worth it to you.
