fork size for clipons
I've got a big craftsman crescent wrench with mm markings on one side and inches on the other. I think it goes to 45 mm.
So there's that.
I just use a caliper though ;)
So there's that.
like I said, if you have wrenches that big chances are you have a caliper in there too.
Interesting set of wrenches though because metrics don't match up exactly to SAE. 1-1/4"=31.75mm, 1-1/2"=38.10. What do the wrenches say?
Never mind, I missed the "crescent" part, Duh
I took the easy way out and have separate metric and standard crescent wrenches.
I've never seen a calibrated crescent wrench before. I mean do you really need it on a crescent?
Re: Re: fork size for clipons
I don't know how accurate mine is, i just hit kids with it when they act up
It has mm readings on one size and inches on the other :D
Interestingly though, as you get into really large socket sets, they stop differentiating between mm and inches. They just have them labeled as both, because at that size the tiny difference doesnt really make any difference.
Back up a couple 'Chard... a crescent isn't a Monkey wrench... a Pipe wrench is closer to a Monkey. They were used for the old square nuts... the head doesn't pivot or have teeth like like Pipe wrench but they look alike.
Now on another note...the Wifey has a monkey and thank GAWD it doesn't have teeth! :o
Cresent wrench...
pipe wrench...
Monkey wrench...
Lady's Monkey...
touché
I stand corrected. I wanted to put a pic of a really hairy ladies monkey in the post, but when that chimp came up I thought it best. ;)
When we hijack a thread, we HIJACK a thread
Sent from planet Earth using mysterious electronic devices and Tapatalk
Hoosier Daddy said:
Crescent wrench...
pipe wrench...
Monkey wrench...
Lady's Monkey...
Of the above, only the last should be allowed near a motorcycle!
(and by that I mean the one in the green shirt)
Crazy
Crazy
What do you mean!?
I use a pipe wrench to tighten my head bolts. Put a cheater bar on the end of it and you can really crank those puppies down. I prefer 423 ft lbs myself.
