CarbsAndCylinders
Careful With That Axe Eugene
It 's looking very nice.
Sonreir said:Looking good.
I'm in a bit late on this one, but you're not using the stock charging system, right?
Also, you can skip one of the ground cables on the M-Unit, if you wanted to save a bit more wiring space. Only one of them is needed.
Kunphushun said:Looking good, seat tray is nice n clean. Ive always liked gold calipers.
The caliper bracket will go back to be coated black. As it’s only the caliper I want to be gold1fasgsxr said:Why not powder coat the caliper? Lots of gold colors available.
I’m not sure, I can definitely say that I know the caliper will have been prepped correctly this time before painting it.The Jimbonaut said:Just a heads up - I used the exact same paint on my caliper (both make and colour) with questionable results to be honest. I followed the instructions, baked the thing after applying the paint, but the first time I tried bleeding the lines and got brake fluid on the caliper it tore right through the paint.
Maybe I messed up somewhere (entirely possible) - you may have better results than me. Good luck! And that frame came out sweet.
maybe I’ll do a test run with it on something else. cb250nproject said:The guys said the powder coating wouldn’t stand the heat. I had every intention of having it coated in the same gold as the rims, as I had left over powder but the guys at the shop red carded it. I figured they would know given they deal with it all the time.
