Getting out swing arm bushings? Best practices?
edelweiss
Coast to Coast
Please see picture below. I heard that getting these bushings out is a real pain in the ass. Will using a sleeve anchor do the trick? Or perhaps a punch tool? I have to take these suckers out before sending out for powder coating.
Try finding the biggest drill bit you have and drill out the center sleeve. You could probably take a flathead screwdriver and pry the rest out. Or if you have a vise, get a spacer a littler smaller than the bushing and close up on it.
Vice or a C clamp and a couple of suitably sized sockets should make a pretty good press.
A bit of WD40 should help them slip out a bit easier, too.
+1 on the press them out with two suitably sized sockets.... oh add heat, them babies will be fused in there but they will surrender!!! 8)
The hardest part to get out is the outer steel sleeve. When the center and rubber are removed. use a hacksaw to cut through the outer sleeve carefully and that will allow it to collapse and come out.
Heat the bushing housing with a propane torch and they will come out easily with the correct size socket.
In the past in a pinch I have put a bolt through, put a nut on it smaller than the sleeve diameter and then pounded it out.
2 sockets and a vice work best though
Use a drill to remove most of the rubber, then press the inner tube out with a socket or tube. Then use a hacksaw, like Taezer suggested, to split the outer tube.
I tried all this shit. I had to resort to the hacksaw in the end. Know my joy.
To get the new ones in, I had to use a vice as a press. They would not fully center until I used a socket to escape the inner sleeve.
+1 on the correct size socket.
I just did these on my GS1000 swingarm. I put it the vice to hold it. Heated, put a large socket on the back side, and then find a socket that fits the outer piece of the bushing, but will go through. Key is to hit that outer part of the bushing.
