Hello All
I'll keep you all posted on the progress of the tank and seat tail set.
Ideally I want to have them completed by late summer early fall. In time for the swap meet that is out in Milton in Oct.
are you useing cad controled milling equip to cut metal? or just use cad to figure things out? cause your work looks sweet.
btw so you know where both grimz and myself druling over your designs for our cb650's cb650 using same tank tunnel as a 750 ;D
grimz said:
hey pyro
whats the sticker on yur forks say for the year?81?
also grimz the 81 forks are totaly different there neumatic over hydrolic where youres are spring over hydrolic, so even axle is conected different, as said night met except for carb and forks otherwise our bikes are identical parts.
I use CAD (Solidworks is the program) to design the parts and make the templates to guide the metalshaping process.
Speaking of milling machines. I am helping a friend retrofit a manual milling machine to CNC. So if it works out decently, I will probably look into designing other bike parts (i.e. rearsets etc),
derant said:
I use CAD (Solidworks is the program) to design the parts and make the templates to guide the the metalshaping.
Speaking of milling machines. I am helping a retrofit a manual milling machine to CNC. So if it works out decently, I will probably look into designing other bike parts (i.e. rearsets etc),
and dont forget lowering blocks ;D
derant said:
Do you have a picture of these lowering blocks?
Which bikes are lowering blocks needed for?
Bring back lowering blocks! They haven't been available since the mid 70s. With all the guys slamming their old Hondas on this board you could probably sell several pairs. The blocks relocate the bottom shock mount about 2 inches back. The 11" shorty shocks are the choice for lowering but they don't work well. With the blocks you can keep the stock shocks. They were made mostly for the CB750 and don't work for the CB350 and CB450. The twins have a chainquard mount on the left side axle mount that gets in the way. It needs to be ground off for the lowering blocks to work on those bikes. Or maybe you can design blocks to work on those bikes, that would be sweet.
There's a pic on this thread:
http://dotheton.com/index.php?topic=1042.0
Here you go...on the 1st page is a pic of the set that I have that Im not gonna use..
They are for an eye to clevis shock application
Cheers
N
cb650 also has the chain gaurd brob, also the shortys at least on the 650 mabe other bikes to make your centre stand useless, unless got two people to lift bike on stand, with blocks you can lift seat with hand and move shock so block is forward instead of aft, making you above stock hiegt allowing easy centre stand access for making repairs.
i believe noel has a original pair you could copy. its basicaly just a eye to clevis adapter .
index.php
derant i was wondering if you could do a simple part basicaly be a nut 1/2" high half way thru tapped to 3/8" thread other side tapped metric 18mm thread with holes meeting in middle, this be a custom petcock adapter to fit a harley pet cock on a honda 650 tank..
Unfortunately I don't have the tools to do this. If I do get the, I'll let you know.
Regarding the part you need. From what I know of NPT threads (which the 3/8" would be) you would need an adapter that is sized larger than 1/2"...more like 1" - 1.5". When threading NPT you need to go a certain depth to ensure that there will be a fit.
i actualy have tools do it now just dont have a piece alluminum to use, what you say is same with metric taps as well cause end of tap is tappered, and since 3/8 is smaller than 20(i missed measured its 20 not 18) you able run tap all the way thru anyways.
Thought I would update this post with my almost complete XS650 Rigid Racer.
I have a few more things to finish up on it (taillight and licence plate holder, speedo, and carb air filters).
So here it is:
...then I have to get cracking on the XS650 Cafe.
I love this bike. Did you buy a hardtail kit, or did your friend build it from scratch? The frame looks super clean. Nice job!
Thanks for the kind words guys :).
The frame on this buike was hardtailed by a friend.
I am pleased with the way it came out. My wife keeps commenting on how clean and simple it looks.
That was my goal really. A bike that reflects the pure essence of a motorcycle...motor, frame, wheels, etc.
Nothing less nothing more. That is my Zen moment there :D.
As far as selling it goes, I am open to offers from interested parties. This is a kick only bike, so that may dissuade some folks.
I may get around to making another one simiar to this next year. I have the parts to do so.
Here is another pic:
