also grimz the 81 forks are totaly different there neumatic over hydrolic where youres are spring over hydrolic, so even axle is conected different, as said night met except for carb and forks otherwise our bikes are identical parts.grimz said:hey pyro
whats the sticker on yur forks say for the year?81?
pyro139 said:are you useing cad controled milling equip to cut metal? or just use cad to figure things out? cause your work looks sweet.
btw so you know where both grimz and myself druling over your designs for our cb650's cb650 using same tank tunnel as a 750 ;D
and dont forget lowering blocks ;Dderant said:I use CAD (Solidworks is the program) to design the parts and make the templates to guide the the metalshaping.
Speaking of milling machines. I am helping a retrofit a manual milling machine to CNC. So if it works out decently, I will probably look into designing other bike parts (i.e. rearsets etc),
derant said:Do you have a picture of these lowering blocks?
Which bikes are lowering blocks needed for?
pyro139 said:derant i was wondering if you could do a simple part basicaly be a nut 1/2" high half way thru tapped to 3/8" thread other side tapped metric 18mm thread with holes meeting in middle, this be a custom petcock adapter to fit a harley pet cock on a honda 650 tank..
i actualy have tools do it now just dont have a piece alluminum to use, what you say is same with metric taps as well cause end of tap is tappered, and since 3/8 is smaller than 20(i missed measured its 20 not 18) you able run tap all the way thru anyways.derant said:Unfortunately I don't have the tools to do this. If I do get the, I'll let you know.
Regarding the part you need. From what I know of NPT threads (which the 3/8" would be) you would need an adapter that is sized larger than 1/2"...more like 1" - 1.5". When threading NPT you need to go a certain depth to ensure that there will be a fit.
