Well to start I had a issue with the tci that I caused. Pos terminal to the frame makes for a bad day. Anyhow I think I corrected that but now it seems I have no power from or to the ac generator. Should I do the radioshack full bridge rec to ser if that solves it if so what about the regulator portion I am not an electrical madter I am still learning. I just don't know what is bad yet. I havent found a wiring diagram that has eliminated everything on the sr250 that I have eliminated. I have headlight tailight, key switch with starter switch ac generator solenoid rectifier with regulator, tci and coil I think that's it so I just need to know the path for all this and that will solve it. And I can get it srarted by running 12v line from ign to red wire on coil but there is no control from yhrottle it just revs high so I am not getting power to the coil properly. I know this is a lot but I am really lost
