hello all
Ifixedit
I am building a nightmare and need help. First chop and I am not giving up uet I just need a little help with this darn thing. :o
Well to start I had a issue with the tci that I caused. Pos terminal to the frame makes for a bad day. Anyhow I think I corrected that but now it seems I have no power from or to the ac generator. Should I do the radioshack full bridge rec to ser if that solves it if so what about the regulator portion I am not an electrical madter I am still learning. I just don't know what is bad yet. I havent found a wiring diagram that has eliminated everything on the sr250 that I have eliminated. I have headlight tailight, key switch with starter switch ac generator solenoid rectifier with regulator, tci and coil I think that's it so I just need to know the path for all this and that will solve it. And I can get it srarted by running 12v line from ign to red wire on coil but there is no control from yhrottle it just revs high so I am not getting power to the coil properly. I know this is a lot but I am really lost
Ok... So its an SR250? Nobody can help you if you don't tell us what bike it is first. :)
I'm a little confused as to what your issues are, though I've only been awake for 15 min so...
Start a build thread. Add lots of pics. Explain your issues as simply as possible. You're way more likely to get help that way.
If it starts and revs high that's not a coil issue, more likely a carb air leak issue.
