Help — CB500/4 engine. Every screw is frozen.
I'm not familiar with that particular unit, on mine you grab the bit holder and Ruth the handle and it changes direction.
To test the movement, don't hit it, just push down firmly and watch the bit it should turn.
It's definitely turning counter clock-wise. Also, the blades on the bit are bent (now a swirl) that shows that it is turning the right way (loosening). Of course, it's befitting that I have another unprecedented moment of having the toughest screws to get out. Will try the roll pin punch next (when it arrives).
Well damn man that's crazy. Does the bit for the whole screw head or is it too small?
Hopefully the roll pin will work
Some of the cheap bits will bend, you need an impact rated bit. The Sears stuff is often the same stuff they sell in HF.
Go to Lowes or HomeDepot and get a replacement bit that is impact rated. With a good bit and hammer, the screw will come loose. The right bit will actually cut into the stripped head a little and turn the screw.
Don't try to turn the screw the full impact driver turn. Hold the driver firm, but let it rotate in your hand. The downward impact, with a small amount of turning force, gets the screw free.
Often, the impact alone will be enough to use a regular screwdriver. The downward impact shocks the threads loose.
Gotta cut down on variables. Shouldn't be that complicated. The blow is what shocks the screws. I'm going to try the roll pin punch when it arrives. Will let you know.
This little tool did the trick — 3/8" Roll Pin Punch tool. 3 good blows on the crank case screws and they came right out (under 8 seconds each). Awesome.
Now, anyone know what to put on these screws and bolts so that they don't freeze up gain? Lithium grease? Or does Loctite make something that seals the threads?
Mate, dump the lot of those old phillip head bolts in the bin and go for a nice shiney set of stainless steel hex drive ones. Ebay is your friend. Lots of ready made kits for lots of bikes available.
I was definitely going to do that and will, but judging from the screws I took out there is no rust, just oxidation. Oxidation could freeze up a stainless screw as easily no?
use a little anti-seize compound on screw whichever type you use,no sealant,do not overtighten ,check tightness after the first few heat cycles
Yup - anti-seize and don't over-tighten. I rarely use a torque wrench on the engine cover bolts - tight is tight, and just use a t-handle. I like the long ones where the handle is made up of the wrench material. Allows you to feel when the handle starts to flex which is IMHO tight enough for engine side-covers.
