Help with handlebar cleanup
grob23
Sketchy, But Effective!
Hello all!
I put new handlebars on my 1976 Honda CB200T and am now in the process of putting things back together. I come from a bicycle background, so cable operated things like throttles and levers aren't difficult for me. Electronics/wiring on the other hand can be a bit of a pain but with my wiring diagram, the internet, and a bit of patience I believe I will get it sorted out.
Right now, I'm trying to figure out how to re-locate the stock switch that controls the headlight High and Low beams. I'd like to replace the stock switch with a toggle, and mount it in the headlight. The function will hopefully remain the same. It's a 2 position selector built into the stock controls, and has a Blue, Blue/White, and White wire coming from the switch. I have the factory Honda manual, which includes the wiring diagram, but I'm having difficulty getting it straight.
The Diagram shows the switch as part of the RIGHT hand controls, the switch is on the LEFT on my bike. The diagram also shows 3 wires (I believe) coming from the switch. A "B", "Br/Wht", and a "Wht". Am I to assume the "B" matches with the blue wire, the "Br/Wht" matches with the Blue/White wire, and the "Wht" wire matches with the white wire? I think the white wire is easy enough...
Lastly, what switch would you recommend? I know little about switches. If I get a switch, can I swap the three said wires back and forth (and try different combinations) without causing harm to the bike?
Thanks for any help!
I did search. For hours. My eyes hurt! Maybe I'm overthinking things, maybe I should stop thinking. I created a thread not too long ago and it's not even off the first page. I'm hoping to not have to make a new thread for every problem I encounter so I attempted to leave this title somewhat open ended. If I'm out of my element or hacking anyone off then OK. Just tell me and I'll go find a different part of the internet to pester
Why not use the stock control switch as intended?
Without looking at a schematic. The only thing that may be harmed is the fuse.
Couple thoughts...
First, toggle switch to go from regular to high beams mounted on a headlight bucket sounds kind of cool, but it's a bit dodgy functionally. When I switch to my high beam, it's when I'm riding and a switch by my thumb is a hell of a lot easier than leaning over the gauges and trying to flick a toggle mounted on the headlight.
Second, don't have a wiring diagram in front of me but Br/Wht is likely brown and white.
Third, if you want to mount the toggle in the headlight, should be easy as the wires from the handlebar switch connect to the wiring harness in the headlight bucket.
I don't like the look honestly... and my mind loves changing things to fit me. Plus I don't want the hassle of either drilling these bars for internal wiring or cutting up my switch housing to run the wires on the outside
carnivorous chicken said:
Couple thoughts...
Although it'd be fumblesome (sp?) I mostly want the looks. I've heard stories of guys wiring their bikes up so that the high beams are always on, without an option for low beams. And I've seen (race) bikes with no headlights at all. My option is surely better than either of those eh?
Couple thoughts...
That was my initial thoughts too. I'm just baffled and cannot find the Blue, or Blue/White wire on the diagram anywhere. I guess they did whatever they wanted in 1976 and the consumer was the least of their worries
My thoughts exactly. This should be easy! I just gotta order a switch... my research isn't telling me anything
Thanks for the replies carnivorous chicken and trek97!
You will need to drill the bars regardless for the lock pin, keeps the controls from spinning around the bar. Its a safety thing. Same as the stock location of the switch. The "looks" really dont matter. The button is gonna be on the control w or without the addition of a pain in the butt toggle, inconveniently mounted on bucket.
I agree you need both low and high beams functional. High only, is nothing short of stupidity. Driving my car I wouldnt hesitate for a second, drowning a guy in blinding bright lights for not dimming his.
Sure, (race) bikes have no headlight.
I didn't know I'd still have to drill a hole, thanks for the info!
I plan to replace everything on the handlebars. I've already ordered a pair of levers (I did my research and they'll jive great with my cable-operated front brake) and a throttle assembly. So I don't plan on using the stock controls at all.
