Hello all!
I put new handlebars on my 1976 Honda CB200T and am now in the process of putting things back together. I come from a bicycle background, so cable operated things like throttles and levers aren't difficult for me. Electronics/wiring on the other hand can be a bit of a pain but with my wiring diagram, the internet, and a bit of patience I believe I will get it sorted out.
Right now, I'm trying to figure out how to re-locate the stock switch that controls the headlight High and Low beams. I'd like to replace the stock switch with a toggle, and mount it in the headlight. The function will hopefully remain the same. It's a 2 position selector built into the stock controls, and has a Blue, Blue/White, and White wire coming from the switch. I have the factory Honda manual, which includes the wiring diagram, but I'm having difficulty getting it straight.
The Diagram shows the switch as part of the RIGHT hand controls, the switch is on the LEFT on my bike. The diagram also shows 3 wires (I believe) coming from the switch. A "B", "Br/Wht", and a "Wht". Am I to assume the "B" matches with the blue wire, the "Br/Wht" matches with the Blue/White wire, and the "Wht" wire matches with the white wire? I think the white wire is easy enough...
Lastly, what switch would you recommend? I know little about switches. If I get a switch, can I swap the three said wires back and forth (and try different combinations) without causing harm to the bike?
Thanks for any help!
I did search. For hours. My eyes hurt! Maybe I'm overthinking things, maybe I should stop thinking. I created a thread not too long ago and it's not even off the first page. I'm hoping to not have to make a new thread for every problem I encounter so I attempted to leave this title somewhat open ended. If I'm out of my element or hacking anyone off then OK. Just tell me and I'll go find a different part of the internet to pester
