Hondazuki XLRM250 Trans-America Hell Ride
Keihin 31mm PD pumper...
Started getting the motor back together...
The carb is proving to be a tight fit, but I think I can make it work...
Not the right size filter, but to illustrate...
Build a glass mini box with UNI foam inside 3D print would be sweet for an ABS air box all formed around the frame and acetone polished :o
I've already ordered a 15° Uni, but a cool box could be fun down the line once it's running. I don't want to get too crazy with variables, since I don't know if the stock jetting in this carb will do. Not too many sources or options for the press fit jets, as far as I can figure.
you are gonna be a bow legged sumbitch with that filter right where you need to have your legs clamping the bike when standing on the pegs
you will be standing on the pegs alot if there is dirt sections
put an elbow up at the head enough degrees to bring the carb in towards center
you can make a steel intake flange with the real short mandarin bend on it then a short section of gates green stripe to clamp the carb spigot,that is what i had back in the day on my bultaco framed xl250 with a central airbox
There's already a 15° elbow on the intake now. I'd have to go 45° to tuck it into the frame. There will be some changes in the frame to accommodate the new shock too.
Tune-A-Fish said:
One these would make a good plug mold
Tune-A-Fish said:
Just fill it with oiled filter foam
Better yet, just carve a positive from foam and cast the foam. That would have to be perfect for the setup to be useful. All they did was mold a positive, made a mold, then rotocast or injection molded the part.
yeah a 45 what is wrong with that ? you cant have that ffilter hanging outside the frame
