Used em as headlights on the 175. They worked on that bike. They're plasma LED rock lights with projector lenses. I haven't tested it above 40mph or off of my street since I have no front brake. Still waiting on the m/c rebuild kit.xb33bsa said:they look like the ones i got but i coont use the ones i got as a headlight :-[ it would sue-ee-side
the bike looks and sounds great! and you have pulled some uphills wot in upper gears?
Header is stock XL. It's a "J" pipe that runs just past the top end. I cut it back a couple of inches to accommodate the bend through the frame. It's CB 750 pipe from there to the muffler. The way the stock 750s run a separate flange that the headers slide onto made it nice for a coupling like fitting at the end of the XL header. I haven't run it with this pipe yet. I ran it with the KX muffler before, which was way too restrictive. It had great torque through the gears though. I need to machine a new end cap with a smaller hole on this one. Right now it's about 3/4" wider at the end than the rest of the exhaust, which makes for a really loud pipe.adventurco said:Pipe looks good. If i get that far, I think I'll do a high exhaust and possibly through frame. Hows it running with that length/muffler? I'm looking to source a relatively cheap can not too loud and looks like it belongs on an offroad bike.
Oh - also - whatd you do for the exhaust collar? Is it from an OEM header or did you turn one up from scratch?
the way the seat is shaped ???deviant said:![]()
First attempt at a seat cover is okay . This shape is hard as hell. I'll wear it out a bit, then redo it.
Please explain how the seat is shaped so almost perfectly wrong. If you mean extremely comfortable, than yeah, it's extremely perfectly wrong. No almost about it.xb33bsa said:the way the seat is shaped ???you wont be innit much anyway
what was reasoning in the thing being shaped so almost perfectly wrong ?
deviant said:Please explain how the seat is shaped so almost perfectly wrong. If you mean extremely comfortable, than yeah, it's extremely perfectly wrong. No almost about it.
deviant said:Haha!
So in their infinite wisdom, Honda designed the head with a hole in it so you can get to a nut on the cylinder head. That hole has a plug which decided to leak. A drain stop in the head. Genius. Got another one machined up.
Shazam!
Haha. Thanks for saying. I'm pretty confident I've got my balls covered. My ass is in the low part of the saddle. Maybe it needs to go up hight, but we'll see I supposed. Sure will feel it if it's not right. LOLxb33bsa said:thats nice workyou need the peg it contacts the rocker cover and pins down that plug. it could just be threaded m6 and a short stud screwed in to correct length ....but you gotta have it ...when i was 15 and got my xl250 in 1973 i decided it coont be that hard to put a big top piston in there
took me fucking forever to find that 4th nut![]()
i didnt have any mechanical experience re engine teardowns,and no shop manual
sorry about dogging the seat but i assumed it was a late april fool and you would unviel the real seat later :-[ :-\ i assumed you had offroad riding experience enough to know
Maritime said:Ha. Nice work Eric. Just ride the piss out if it. Oh and I am officially whisky drunk and full of IV antibiotics so my opinion is brilliant and I'm automatically smarter than I was a day ago.
