Rich Ard said:I'll just melt the tank down and make a new tank out of it
notlob said:IIRC its a CB tank you have. ON mine I used a 4" grinder on the spot welds, if you grind it down enough to bend the tabs off without pulling through the tank, then just clean up the spot welds.
AlphaDogChoppers said:There is not good reason whatever for not using Bondo.
Solder/lead as a body filler is from the 60's. WAAAY better materials for the job now.
I'll modify that statement slightly. If you were going to metal plate the tank, you would use a solder type of filler.
3" grinder, grind just through the spot weld it self and those straps fall right off. Just did it to a set of Fat Bob tanks.Rich Ard said:I only have a four inch grinder and a Dremel - I think that for me, belt sander is the way to go.
What would you use to grind the spot welds off? I'm sure the Dremel would get there...eventually...
o1marc said:3" grinder, grind just through the spot weld it self and those straps fall right off. Just did it to a set of Fat Bob tanks.
Nebr_Rex said:Where did you get a 3" grinder? I need more tools.![]()
pterodactyl said:I have a couple of tanks that have the holes and was wondering if they could be filled in with brass almost completely flush?
Rich Ard said:Grinding it off pre-bondo is definitely easier, having now done it both ways.
