DohcBikes
Fuck You.
Its been a minute since ive had a kz200 apart so I dont remember the exact design but in other words do you have the tensioner set where the tension would be the least or not at all when installed
Also i am not convinced that the mark you show on the flywheel is TDC because it is very hard to see. Confirm tdc by shining a light in the plug hole and finding the point of piston dwell at the top of the stroke. Whatever mark is close to the pointer on the flywheel cover when the piston is motionless at the top of the stroke is your mark
