KZ 400 wiring thread
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
Hey guys!
Last week i received my sweet loom of Sparck Moto,thanks again Matthew for your great support,i cannot wait to put it into my bike!
This will be mh thread where i will post questions and pics of the problems i might face.
Cheers guys!
Sonreir said:
Following along. ;D
thank you!the loom looks great!perfectly made connections,super clean and quality connectors!i´ll def have questions and issues coming your way :)
So i had time today sat down and tried to figure out where the connections will go.
Some questions arose.hope you can help.
Pic 1:
What are these 2 cables going,am i guessing right and these go to the rear brake sensor assembly?
Pic 2:
Where do these 4wires go?purple,2 times yellow and pink,are they going to the oil pressure sensor and...?
Pic 3:
These wires get hidden in the bucket dont they?they are connected to the left and right hand assembly and the tach control lights right?
Thanks in advance!
1.) Correct.
2.) Oil pressure, neutral wire, and the two AC wires for the alternator.
3.) Yes, if possible. They can also fit under the tank in many circumstances.
Hey guys finally had time starting with the wiring....was busy with my RD.
So here i go again:
Pic 1.)i m starting connecting my DCC mini tach.
Am i doing this right that i bullett connect the harness the plus cables of the functions (the black striped red blue green et cetera wires are ground when i remember correctly)?
Where do the black striped wires go?maybe altogether in black the ground?
Pic2.)these are the wires for bright light (blue), back light ??(orange and black) and yelliw for tue blinker control light...where do they go in the harness cant find a suitable place...
Pic3.)does the blue brake cable go into the sensor,what does connect to the other connector of the sensor is there maybe a ground?
Pic4.)where do these three go?white goes to start button of the hand control yellow has a male connector but no sign on it and orange has 'signal main' on it.
Pic 5.)how do i use this plug it has three contacts black blue and red.does the red from the plug go into the bullett conn of the horn?
Hope you can help me!!
Lets do one thing at a time.
First up, your tachometer.
It's LED, so each light will have a definite positive and negative wire.
The neutral (green) and oil pressure (red) wires will be activated by a switched ground. This means the green/black goes to the neutral wire and the red/black goes to the oil pressure wire. The green and red can be tied together and connected to a power source (along with the power for the gauge back light(orange?) if you don't mind having it on all the time).
Ground wires (the ones with the black stripes) for the high beam light (blue), turn signal light (yellow), and gauge backlight (black?) can all be tied together and grounded.
This leaves the power wire for the turn signal indicator and the high beam indicator. High beam is the easy one (blue) and can be tapped into the high beam wire. There is usually a plug for this in the headlight as part of the pigtail but may also be attached to the left hand control assembly.
The turn signal (yellow wire) will be the tricky one. With an LED setup, you'll need diodes to provide a one-way signal to the indicator light. I can't remembered if you ordered this option when you got the harness, but it will be an orange and a blue wire heat shrinked together with a black wire coming out the other end. If you didn't order it, you're going to need to get some diodes and start soldering. Details here: http://www.dotheton.com/forum/index.php?topic=44556.msg486851#msg486851
So far so good!
Here more questions :-)
Connected the regulator to the plug you made (2 yellow 1 black).where does the white red wire go?am i right that it goes to tje double bullett with the alternator like shown in pic2?
Question 2
The solenoid has 1 wire going in and 2 wires going out.
In: battery plus and on the same place out: white red which goes to the regulator (as in question 1)
Other pole two wires out:black and yellow red.
Am i right that the yellow red goes into the white from your loom?
Where does the black go?ground?
Does the red battery plus with connect to the other pole where the white red wire goes out to the reg?
Thanks in advance!
Red/white wire goes to battery +.
For the solenoid, yellow/red gets power when the ignition switch is on (brown wire in the harness), black goes to the starter button (white wire in the harness).
If the other wire is white/red, then that goes to the battery + terminal.
Ok sonreir.i drew a little diagram.is this right?two questions are marked red.
1.)the battery plus should be connected together with the red/white on the one side of the solenoid.can i just connect your thick red batt plus cable with the fuse to the contact(togehter with red white,the stock batt plus cable that runs to the batt box)?
2.)in which brown plug or bullett can i connect the red yelloe of the solenoid?guess it doesnt matter or am i wrong?
Thanks in advance!
1.) The battery + cable from the harness needs to attach to the bolt terminal on the solenoid. The same one with the red stripe in your picture.
2.) Any brown is fine.
Thanks for the insight!
Pic 1-2:my blinker relais has two contacts.i guess one will be ground and the other is for your orange cable shown in pic2?there is B and L written on the relais,which one is ground?
Pic3:i alredy asked you about this but just to be sure:the 2 yellow cables coming from the engine go into the 2 yellow bullets shown in pic3...does it matter which one in which(hard to say when both are yellow :-))
Where does the black (ground?) And light green go?is the light green oil or neutral light?
Thanks for your help!!
Neither are ground. B stands for "Battery". It gets power from a brown wire. The other, the L, stands for "Load". That's the one for the orange wire.
Either yellow is fine. Doesn't matter which. Check the instructions for the colors on the other wires. I can't remember off the top of my head.
I guess I am right in this section?
Charging System
If your harness comes equipped with an aftermarket regulator/rectifier (singles and twins only), it will also include a short run of wires that terminate in a square plastic connector with four wires (three wires if not using neutral light). This connector will plug directly into the wire coming from the left side of the engine, which begins at the alternator.
On the opposite end, there will be a pink and a yellow wire that should be connected to the outside terminals of the R/R. Finally, a red wire running from the middle terminal will be connected to the positive terminal of the battery, but leave this wire disconnected from the battery, for now.
Sorry i cant find where the black and green (coming from the engine)should go in your harness...
