KZ550- Iron Geek K Zeta
M.B Co said:
How did you wire the new ign. setup? Any odd things to look out for?
Um... still got to work out a few bugs on that one. I stripped a lot of wiring out of the harness but basically I looked at the wiring dagram and put all of those wires onto the new one in addition to the starter button wires. This is a turn-key start, so it will be just like a car ignition instead of pressing a button. There will be a little bit of trial and error but it should work well.
i'd be very interested in details on that turn key start once you get it working correctly. i have one sitting around waiting to go in my build.
motor is in....
Been working a lot on the bike. Tomorrow the bike will be cranked and turn on...... we hope. Anyways some pictures. Used metal rescue on the inside of the tank, worked like a charm. and hid the light switch under the seat
more photos. fixed the oil leak with a new seal
Failure #1 on starting the bike.......
MotorbikeBruno said:
OH man! I can't wait for you to fire this thing up! Isn't wiring fun! haha
Hey, what did you do about all the breather's and hoses everywhere?
I blocked them off. I have some large heatshrink with glue in it so I sealed them off that way. You don't need them, and they make actual block-off kits for them on the net at about $50 if I remember... The oil/crank case breather under the carbs got it's own little air filter for a car crankcase filter $10 or so at the auto store, and the two going to the carburetors were capped. I always found the air-switcher thing to be a pain in the ass on the Kawi's There should be ONE line coming from any of the 4 carburetors sync ports that goes into the gas tank vaccum port. Hope that helps.
Bruno
Bruno
Big thanks Bruno,
That helped a lot
