MotorbikeBruno
Over 1,000 Posts
PeteyWash said:So,
From here we need to get the front brake properly mounted. Definitely need to get into the carbs and check out the valves, because this bike does not run well. After that the list is as follows:
paint tail
upholster seat
tail light
sand, polish, and clear the tank
rear sets?
properly mount ignition
............... you never really do finish do you
When you do the valves, check the clearances and write them all down. These use the under-the-bucket shims. That way, if you know you are too tight, you can go one size thinner on the next one. But you'll only be able to know that by taking measurements and writing them down first. Also, if you don't have one yet, get a micrometer. Many of the shims have lost the marking telling you what size they are. Just a heads up! She's looking better and better sir! 8)
