Lacking top end speed. CB400T
woodardhsd
I got a 78 CB400T that I have been been tinkering with for a year or so. I went through the carbs completely and made sure everything was spotless. New gasket set, air-cut diaphragms, syncronized, everything. The stock jets are 75 primary, 110 secondary. I upped the primary to an 80 which smoothed out the midrange quite a bit. Air box is stock, the mufflers are aftermarket, but are very similar to stock. Still have the heavy stock H-pipe. The bike runs great around town, accelerates smooth once warmed up, but wont run more that 80-85 on the highway. I have tires a little larger than stock (110/90-18 vw 4.10-18) so I replaced the sprockets to shorten the gears back up some. The ratio's are just a hair shorter than stock. I'm only at 7500 rpm around 80 mph so I don't think it's gear related. I've removed a few pieces to lower the weight of the bike a little (lighter front rotor, no rear pegs, no tool-kit under the seat, and the crash bar) I weigh around 180, but am 6'2" so I probably create quite a bit of drag, but even tucked in as much as I can, I still struggle to get over 80.
Anything I might be overlooking? After running with the throttle wide open for a minute or two, I'll throttle back to slow down, but when I do, the engine seems to want to speed back up a little for a second. It seems I read somewhere that indicated a lean condition, but when I switched out the secondary jets for 120's, it didn't help much. Plugs look good, by the way.
-Mike
Id check for good fuel flow from the petcock then if that didnt work id check the fuel level in the bowls (Not just the float bowl height).
First Question 80-85 MPH or KPH? Big difference if it is MPH, thats as fast as the bike goes with someone your size. If it is KPH you do have a problem. I had/have the same bike only an 81, it did 120 KPH (75 MPH) at 7,500 RPM. I could get it to 80-85 MPH at 8,500 and that is as far as it would go with 200 lb rider. That motor was running lean and I didn't know and it blew at 7,000 RPM on the highway on my way to work one morning. I then put a 450 twin from an 82 in the bike and learned a boat load about carbs and lean and rich etc. The bike now does the same speeds at about 500 rpm less with no lean conditions. It is a 6 speed now and I have hit 90 MPH Approx 140 kph easily. Open exhaust with shorty emgos, pods, re-jetted to 74 and 128 jets, adjusted air screws and idle. To get the right combo I test road for days at steady RPM levels shutting the engine down and checking plugs to see if they were fouling or white etc. This combo gave the bike brown to slightly black plugs at all RPM's, no worries about lean and only slightly rich sometimes, never fouls plugs, and I have put about 5000 KM on this motor this season.
Cheers,
Maritime
Yeah, thats MPH. I realize that I'm a little to big for this bike, but it'll have to do until I can get my SV.
I tried the "plug chop" the other night. I got the bike warm, and ran it up to 85, kept the throttle wide open another 10-15 seconds and cut it off and coasted to a stop. The plugs were quite white, probably #23 on this page: http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html . Rode back home cruising around 55, part throttle, like I would normally ride to work in the morning. Cut it off and checked the plugs again. They looked the same. Maybe I'll try the 120 jets again later.
I mean, the bike runs really good around town. It accelerates through the gears real smooth, it's just lacking up at highway speed. It's kinda scary to pass people sometimes.
Did a little more research about my carbs and it turns out the stock jets are 75 and 105. I pulled these original jets out of the spare carb set I had and put them in. I can tell a difference in the low to mid-range, the 75's bogged a little more. The top end was the same.
From what I've read online, these CV carbs tend to run lean, no matter what. The DOHC CB Supersport guys have the same problem. The plugs stay white.
I'm just gonna play around a little more and see which combination rides better. This bike is never going to be fast
