woodardhsd
I got a 78 CB400T that I have been been tinkering with for a year or so. I went through the carbs completely and made sure everything was spotless. New gasket set, air-cut diaphragms, syncronized, everything. The stock jets are 75 primary, 110 secondary. I upped the primary to an 80 which smoothed out the midrange quite a bit. Air box is stock, the mufflers are aftermarket, but are very similar to stock. Still have the heavy stock H-pipe. The bike runs great around town, accelerates smooth once warmed up, but wont run more that 80-85 on the highway. I have tires a little larger than stock (110/90-18 vw 4.10-18) so I replaced the sprockets to shorten the gears back up some. The ratio's are just a hair shorter than stock. I'm only at 7500 rpm around 80 mph so I don't think it's gear related. I've removed a few pieces to lower the weight of the bike a little (lighter front rotor, no rear pegs, no tool-kit under the seat, and the crash bar) I weigh around 180, but am 6'2" so I probably create quite a bit of drag, but even tucked in as much as I can, I still struggle to get over 80.
Anything I might be overlooking? After running with the throttle wide open for a minute or two, I'll throttle back to slow down, but when I do, the engine seems to want to speed back up a little for a second. It seems I read somewhere that indicated a lean condition, but when I switched out the secondary jets for 120's, it didn't help much. Plugs look good, by the way.
-Mike
-Mike
