mydlyfkryzis
当有疑问时踢你的敌人在生殖器上,你可以道歉后
Stock CL was more like high 80's as it had a slightly lower sprocket ratio. My 69 CB completely stock would break 100 on level ground. It could pin the tach in 5th gear. The speedo would bounce all around at those speeds and was unreliable. At 12k RPM, I was a bit north of the ton. That wass laying flat as possible on the tank.Sonreir said:On flat ground with no wind, the 350 is good for mid 90s.
I wouldn't have the courage to drive as fast today, age has made me wiser.
