My frankenturd
Re: My first build
Yeah, very different. Again, sorry for not paying attention to details here. Saw cb750, so used to dealing with sohc4's that I skipped right over the part where you said '79.
I've only worked on a couple of of cb dohc 4's, my knowledge is limited on them.
I've heard tell that the cb900 engine will fit the 750 frame, with the top side being a tad tight, because the engine is taller.
Re: My first build
I have a cb900 engine for sale.
I've heard that you can install the cb900 cams in the cb750 engine for a considerable performance increase.
Re: My first build
Alpha, shoot me a PM with the price on that 900. Like I said, I have a line on a SOHC 750... dirt cheap, but a couple hour ride each way. There are a couple of DOHC motors but the same 2-3 hour drive.
I picked up the frame today. Figured what the hell, like others said, I can part it all out for more than 200. He included the cut frame section, stock swing arm and a ton of other parts. I will get an inventory of what I got. Keeping on the look out for a tank too.
Re: My first build
You may need to do a little research. This CB900 is shaft drive, but I think it can be converted to chain drive. There is a Hi-Lo gearbox on the left side that is part of what makes it shaft drive, I think.
You will also need the carburetors, which I have, and the ignition modules, which I don't.
Re: My first build
Yub, keep a lookout for the F model 900 engine. I mean, yeah, chain conversion prolly possible, but prolly a lot of work.
Re: My first build
So I have had an interesting turn of events. I found a "whole-ish" 78 which I am going to pick up in the next day or two. Typical rusty, motor will fire but not stay running, no title type of bike. Just what I was lookin for. I know this is an SOHC motor... the frame is in tact... I guess I will see what I come up with when I get it all home and look at the pile of parts...
Re: My first build
78k or f?
While the 78k's were ugly (at least in my opinion), they were really super solid machines with a lot more power than their mid 70's (k4-k6) older brothers.
Re: My first build
Yeah, its a K8 bike... I took a look at it Saturday... guy got it fired off and I loaded it up and brought it on home. Probably just going to get rid of the 79 frame and use the matched pair... less work involved.
Re: My first build
I say ya get the k8 running well, then, since you have a running bike, you can take all the time you need to make a kickass DOHC.
Check out this beautiful cb750f, Honda factory racebike, these were badass: http://www.sportrider.com/features/146_0910_honda_collection_hall_motegi/photo_21.html
Re: My first build
Yeah, I'll see what I have left after I build the K8... might be able to put together another bike when it is all said and done.
Figure while having the motor out... I'll take a look at the topend, at least hone, rings and gaskets. Not really looking for a racebike... but a reliable one. The thought of tearing into the bottom end and trans is on my mind... but I am a little apprehensive. We'll see what I come across when that time comes. The wiring on the 78 looks like wiring would on something 35 years old... brittle and hacked all to hell. So I figure I will be making my own harness which is fine... not too difficult.
Re: My first build
It's been a week since I updated this thing... I have been trying to track down what parts are off what and get a good inventory of what all I have. From what I gathered the wheels and tires are off of a Kaw ninja, the forks are off of a 94-97 VFR750 and the swingarm is off of an 07-08 gsxr1000. I have been working on a plan of attack so I am not just tearing into this thing with no direction...
I took the forks and swingarm off the 78 and test fit the sportbike parts off the 79 frame on the 78 frame. Stuck the tank up there and realized just how wide that b!tch is. Allballs makes a conversion kit for the VFR to CB forks, so there is no real issue there... the pivot for the swingarm is much larger on the GSXR swingarm. So, I need to decide if that is the swingarm I really want to use... and if so, I need to modify the frame accordingly. Also, looking at going monoshock. So I will be playing with shock angle and mounting options. I want to keep the beefy 630 chain and found a matching sprocket for the kaw rim.
The tank is just way too wide. So I got to work with the whizz wheel and started making cuts. The plan is to narrow and add some knee indents. I didnt care for the recessed filler cap, so I cut that out and plan to weld in the stock flip open cover. I started a thread in tanks about modifications and posted the pics up over there... didnt want to post them twice, but I'll attach a pic of the tank progress so far.
I plan to run a 2 person seat, but make a removable cowl. I want to run a big headlight... something in the 7" range... and most likely go with a speedo/idiot light combo gauge.
Re: My first build
Think about doing a dual headlight. Optimize one for high beam, and the other for low beam. You'd have to be sure you have the power for that first, though.
Re: My first build
Been a while since I updated this... I have had a ton of stuff going on so I haven't had much time to tinker with the bike. Here is the little bit I have done to it. I got the motor fired off a while back, really didn't take much to get her to run. The VFR750 stem was too short so I pressed the stock stem out of the CB tree and pressed it into the VFR tree. Then I ordered a set of tapered bearings for the stock 78 front (should be here in the next few days). I have cut the shit out of the tank and started narrowing it. Still have a ton of work on the tank to do. My 220V welder isn't the best for sheetmetal work so I gotta go use my buddies little miller 110 to finish up the tank. Finally, I have cut off a lot of the old tabs off the frame and started mocking up the gsxr swingarm.
On a side note I was cleaning out the extra bedroom making space for the forthcoming baby... and came across this old pic from where I was 4. Turns out my pops had an old DOHC 750! He hadn't seen my project until this past weekend and once he did he tripped out. Talked bikes all afternoon. Pretty cool.
Re: My first build
Looks like you're on your way here. While your initial idea with the rolling chassis was admirable and would have been a totally bitchin ride with Alpha's CB900 engine, I think you chose wisely in starting with a complete bike. I dont have alot of bike builds under me, but enough to know that it's always easier to start with a complete machine. Even if you dont plan on using all the parts and peices or have a specific powerplant in mind, you have trading stock, and I usually make enough money by selling off parts I dont want or need to recoupe the buy-in cost of the donor bike, if not pay for the whole machine!
It sounds like you have good experience, and looking at what you have going on so far I think this will be a good build.
Re: My first build
Tinkered a bit through the holidays... I welded a new tunnel in the tank, got a new bung and cap for the tank. The bung is steel and the cap is aluminum and has a brass vent in the side. Welded up a mount for the all in 1 tail light.
Re: My first build
Also had some new swing arm bushings made up, and after I took some measurements for the suspension... cut some tube and the mounts on the cnc... tacked everything in place. She's a roller again... and a pic of her current state
Haven't had too much of an update due to 2 weeks of snow...
Started on the seat, made it out of 16ga. Then I did the carpet padding trick. Pretty comfy. I wasn't happy with the handle bars so I ordered some new clip ons, I like their position better. New front master cylinder came in and mounted up so I ordered all my brake lines. Got the rear master mount made and tacked into place. Rear fender came in and got that mounted up. I also found a guy with a bunch of cb750 parts... I picked up a 4 into 2 header... one that pairs 4 & 1, and 2 & 3. Suggestions for short mufflers? Where do most guys get their conical mufflers?
I used the old distilled vinegar trick for the surface rust in the tank. That worked awesome, then used that KBS tank sealer inside. Poured it in, rolled around the tank for about 30 mins and let it drain upside down. In a couple of hours it was cured hard. I then started some body work on the tank... a million hours of sanding on the tank.
Quick question about oil tanks. I am trying to figure out where I am going to put an oil tank... I want to say everyone makes their oil tanks with a 3 quart capacity right?
Also, I have come to the realization that I cant fit that AGM battery I have anywhere without it looking goofy. So I am going to order a new combo reg/rec unit (one I ordered early January got "lost in the mail") and go with a lithium battery.
