Re: My first build
It's been a week since I updated this thing... I have been trying to track down what parts are off what and get a good inventory of what all I have. From what I gathered the wheels and tires are off of a Kaw ninja, the forks are off of a 94-97 VFR750 and the swingarm is off of an 07-08 gsxr1000. I have been working on a plan of attack so I am not just tearing into this thing with no direction...
I took the forks and swingarm off the 78 and test fit the sportbike parts off the 79 frame on the 78 frame. Stuck the tank up there and realized just how wide that b!tch is. Allballs makes a conversion kit for the VFR to CB forks, so there is no real issue there... the pivot for the swingarm is much larger on the GSXR swingarm. So, I need to decide if that is the swingarm I really want to use... and if so, I need to modify the frame accordingly. Also, looking at going monoshock. So I will be playing with shock angle and mounting options. I want to keep the beefy 630 chain and found a matching sprocket for the kaw rim.
The tank is just way too wide. So I got to work with the whizz wheel and started making cuts. The plan is to narrow and add some knee indents. I didnt care for the recessed filler cap, so I cut that out and plan to weld in the stock flip open cover. I started a thread in tanks about modifications and posted the pics up over there... didnt want to post them twice, but I'll attach a pic of the tank progress so far.
I plan to run a 2 person seat, but make a removable cowl. I want to run a big headlight... something in the 7" range... and most likely go with a speedo/idiot light combo gauge.
