My idle sucks!
Thats definately not it for my problem, my carbs are set up perfectly as far as i can tell (light brown through all throttle ranges and idle, and no weird vibrations.)
I think i finally, for real, figured it out though. I stopped today and for some reason, with the bike still running, i decided to lift the seat. All of a sudden this puff of smoke hits me in the face. At first im thinking, what the hell was that, and im feeling around to see if anything under the seat is abnormally hot, but i dont see anything. so i get down on the ground and im looking around for gas or oil or something dripping and it hits me. NO crankcase breather hose. I have no idea how i missed it with the number of times ive had that valve cover off, or the tank off, or the carbs off, but its not there. I was reading over on SOHC4 that this guy was having bad idle problems and some weird stumbling and he traced it back to wind blowing over his breather hose creating a venturi effect (vacuum). So im thinking the same things happening to me, except instead of blowing over the end of the hose, its blowing right over the vent. Would explain the inconsistency and why it fluctuates from normal to high to mid back to normal, i think.
So im going to get some breather hose and see if that fixes it up. Anyone know what size hose and what type i need for the 450? I tried checking my manual and its not in there, i have some 1/8th inch hose but i think its too small, and im not sure it would stand up to the heat (the valve covers get hot, obviously).
Bobjy,,,,,,thats not your problem..breather hose just vents crankcase pressure to atmosphere(or your air box)...what you have read(cycle world) is a strong cross wind blowing past the carb vent tubes and changing the atmospheric pressure above the float chamber,,,resulting in poor performance.......good luck sorting it out ;)
Damn. Any other ideas on what it could be? Im literally stumped then. Ive looked at everything... no vacuum leaks, float heights are fine, slides arent sticking, throttles not sticking, timings fine, fuel is flowing, spark is good on both sides, both carbs are as in sync as theyre gonna get without vacuum ports... The only thing i can think is that the spark advancer is sticking but it doesnt look like it is.
I've been following this issue on and off, one thing everyones said (including me) is air mixture screw. I don't recall if the OP has checked/adjusted them yet. I breify scanned thru and didn't see anything. If you have, I'm sorry. If not, I have a funny feeling that's the issue.
Good Luck.
Bob, somebody else had a very strange problem with their motor (can't remember who or what exactly), but after much probing and prodding it ended up being an exhaust leak. They had messed with the headers and they weren't sealed properly.
Hopefully you get this gremlin figured out.
Nope, its not the pilot screws. I somehow managed to get the carbs bang on perfect when i resyncd after someone here suggested it.
I dont have any exhaust leak at the header, but i do have a slight leak where the header pipes meet the muffler on both sides. I havent been able to find anything to seal that up. Id need like a rubber-ish gasket or something becuase both sides of the pipes are slightly out of round, havent been able to find one. Could that really be it?
Ive also been thinking maybe its my air filters. Im not running pods, but im also not running the stock airbox. The previous owner used the Uni sock-style filters. Maybe theyre catching a weird breeze? Seems kind of unlikely though because they sit entirely behind the side covers, and ive never heard of that happening.
Ok so i think i finally got an answer to this, but its not the answer i was hoping for. I had it up at the shop to get my sloppy shifter fixed since i didnt have the tools to pull the oil filter off, and i mentioned it to the guy. He said on the early 450s there was a tendency for the carbs to get warm and vaporize the gas in the bowls, which then causes the idle to hang when you back off the throttle, which is probably what im seeing. He said my sync was bang on, and he didnt see anything else that would cause the idle to hang. Basically he said dont worry about it, nothing i can do.
Ive never heard that before but then again i dont know a lot of people who are running the 450's, and this guy seemed to be pretty knowledgeable, hes been working on bikes since the 450 was new in the showroom, so im inclined to believe him. Considering ive done literally everything i can think of to solve this issue and nothing has worked, its pretty tempting to believe it might be something outside my control.
Not that I'm not saying thats it, but that would have to get pretty hot to do that, wouldn't it? Wouldn't the CL's have that problem then, since the exhaust is pretty much next to the left side carb? Not trying to be sarcastic, just trying to brainstorm with ya.
Yeah no i appreciate that fully. Honestly im completely stumped, and everything everyone here has suggested, ive tried. Ive also tried other things on my own. If anyone else has any other ideas, im fully ready and willing to try them because it seems weird this bike would have a design flaw this glaring (and youre right, the CL's would have it too). However, this is the only person ive met who could give any kind of explanation as to whats going on, and he didnt say it as if it was a theory, he said it like "Nah, this is whats happening, nothing you can do". He could be wrong but i dunno. Like i said, im completely stumped.
So what's the solution? Don't know if the Mikuni's are the answer, but you might try making some little air scoops to divert cool air to the carbs. Or some heat shields in front / below your carbs now.
Might look goofy, but who knows, just might work for you.
Haven't read all posts but carbs heating up sounds perfectly feasible to me.
Honda used air dams built into manifold spacers on some models to stop hot air heating up float bowls (other manufacturers do same, even BSA in 1950's, although that was mainly to prevent fuel dripping into magneto)
As for 'smoke' when you lifted seat, oil/water vapor out of breather into filters can and does affect carburation.
What oil are you using?
It needs to be motorcycle specific (or diesel oil with high ZDDP)
I was using the rotella diesel oil since i found it worked really well in my 125. Right now ive got some castrol bike oil in though since i had a bunch lying around and wanted to get rid of it.
Ill throw that breather hose on before i take it for another ride and see if that helps it at all. Thanks for the advice PJ.
As for the final solution big r, i dunno. Air dams could help and i might try that if i can find a cool way to set them up. Mikunis also might help since letting off the throttle drops the slide and cuts off the fuel and air flow other than strictly through the idle circuit. Other than that, i might just forget about it since its more of an annoyance rather than being harmful to the engine. If it was idling up to like 5k and sitting there id be more inclined to do something, since sitting in traffic itd be way more likely to overheat. But because it only hangs at around 2k, and comes back down eventually, its something i could try and accept. Hard for me though, im a bit of a perfectionist when it comes to how my bikes run ;D
Ok, update on this thread too since im on a roll fixing my screw-ups ;D
This was mostly caused by the missing breather hose. Finally got some hose (its 1/2" incase anyones curious, NO ONE stocks 1/2" heat resistant rubber hose in toronto for some odd reason, had to get some used stuff from TO Cycle, and its not ideal, its fuel injection line, very thick) and routed it out the back of the bike. Problem mostly solved, It still has a slight slight hang at 2k about 10% of the time, but no where near as bad as it was, its like a split second and then back down to a normal idle. I think the carbs getting warm is the rest of the problem as mentioned by the mechanic and confirmed as plausible by PJ. If i reach down when it happens, the bowls are warm enough, in my opinion, for gas to vaporize slightly.
So, long story short, i finally have a fully running bike! Put 100 miles on it today :D Best 100 miles ive ever done on a bike, it felt so rewarding.
It's probably a little lean causing hang up (extra heat getting to float bowls)
PJ
Its actually a bit rich. I had a nice brown/tan color on the plugs, and i backed the idle screws out about 1/16th turn to see if that was causing my other problem (misfiring, which it was not). Now theyre still brown but a bit darker. If anything i would guess the carbs are slightly out of sync since i dont have a vacuum port so i had to do my best by ear. But no weird hesitation or vibrations so i think its about the best im gonna get out of these carbs.
So adding more length of hose gave the back pressure to not vent too much pressure loss through the top end?
I think as PJ mentioned it was more the fact that it was breathing right into filters, and probably a tiny bit of a venturi effect from wind rushing over the opening. Not exactly sure what the scientific reason is though.
