New Honda CB350T Bolt-On Rear Sets, Universal, Adjustable Rear Sets As Well
J-Rod10
Over 1,000 Posts
DTT BOTM WINNER
I've revised my 350 rear sets, they are now direct bolt on's, and far more efficient. The stock brake switch works, with no need to relocate, stock return spring as well. They are fully adjustable, due to the new linkage I have come up with for them. Stock kickstart works as well.
Also, the levers are aluminum. These are ones that are going on a personal bike that were painted black.
P1010020_zps6662f841.jpg[img]
http://i1095.photobucket.com/albums/i467/ViperBaseball14/P1010017_zps974b07d5.jpg[/img]
This photo shows what is coming along with this kit.
I can also make this set universally. If you can give me measurements to where you're going to mount, to the brake/shift shaft, I can make linkage. These as well, will be aluminum.
We are asking $175 for the 350 Bolt-On Kit.
We are asking $150 for sets with custom linkage.
We are asking $125 for pegs and levers for those who want to do their own linkage.
Every aspect of these are made/machined here in the good ole USA, by myself and/or my father. Pegs, levers, linkage, connections, are all milled/turned at our shop.
Do the levers have ball bearings or do they just sit over the pegs? Id love a nice universal ball-bearing lever setup.
Yeah, I'd like to know too. Also, my braces for my mufflers bolt to my rear passenger peg spot. Are the bolts on this rear set long enough to accommodate that?
They use bushings. I've had a set of these on my personal bike since 2008, just as smooth as they were the day I put them on. Everything is polished out and greased properly prior to them being shipped out.
Face,
Yes, they are plenty long enough.
Matt,
I can do these with needle bearings, at an additional cost. I'd have to do a little research and see precisely which bearings I need, and what they are going to cost.
I don't personally have a 360 to pattern a bolt on kit for.
I can however make pegs, levers, and linkage if you can tell me how far from where you plan to mount them to the brake and shift shaft.
I'm thinking I want to mount them where the passenger pegs are bolted now. What measurements do you need? Sorry, I'm a bit of a newb.
Sent from my iPad using Tapatalk HD
I would need the lengths from where you plan to mount the pegs, to where they will attach to the shift shaft, and brake shaft.
If you plan to mount them to the passenger pegs, and can tell me +/- 1" the length rods you need, I can build them.
