New Honda CB350T Bolt-On Rear Sets, Universal, Adjustable Rear Sets As Well
I have a few sets of universals with me at Mid-Ohio if anyone wants to take a gander.
In section DD.
I just need a good linkage rod on the brake side, the rod I have is not quality enough. It is about 18" long and needs about a 2" offset to clear the shock. I will get better measurement later I am mostly looking to see if you will do it and for roughly how much.
What bike is that on?
I'll be honest with you man, I absolutely hate building linkage rods with bends in them. As you have noticed, they are not strong enough. What I typically do in that situation, is the same as the shift side, run a rod forward to the brake shaft (same as the first pics on this thread of the CB350T), that makes use of the stock brake rod. Which also allows you to use the stock brake switch, and return spring.
RUF,
I do not believe I have sold any to anyone with a 125.
It is an 82 Nighthawk 450. the trouble with using the stock pivot arm is it is near impossible to get to because the aluminum frame brace is in the way. If you know that it is not needed I would trash it in a heart beat but I have a sad feeling honda put it there for a good reason. the stock brake actually even uses the same axle as the center stand did. I totally understand the not making bent rods thank you for even replying!
Can you send me a pm. Very interested but was wondering if the linkage could be run from the bottom of the rear set rather than the top, like the dcc indexible ones.
Sent from my SCH-I535 using Tapatalk 2
To everyone who has placed an order over the weekend:
I just rolled in from Mid-Ohio. I'm going to catch some Z's, get linkage and pivot pieces wrapped up for the 350 sets, and hopefully have them all out to you tomorrow.
All of the 350 sets that have been ordered are on their way out.
The 360, and 750 will be out tomorrow.
Thanks again guys!
Does anyone have a pic of these on their bike? I can't seem to be able to put them anywhere but parallel with the ground but that leaves me no ability to shift up at all due to limitations on the human ankle. If I put them less than parallel I can get my foot between the lever and the muffler.
May help to post a pic up, to see if anyone is running the same, or similar exhaust as you are.
For future reference.
If you are running aftermarket exhaust on the 350, please inform me before hand. I can't guarantee that these will work with multiple other exhaust systems. I know they work with stock mufflers, and close to stock (diameter under pegs). I designed them, they work.
As you can read on our website (link is on the left of the DTT page) we do not do refunds on custom pieces. These are not mass produced on a CNC. Each set is done manually on a rotary table.
It's irritating to put in hours on a set, and someone get them and say they do not work, because they have a big aftermarket exhaust can directly under the pegs.
So, please, in the future, let me know that before hand.
Thanks guys!
