Nj732port
Coast to Coast
grcamna5 said:Looks good 8)
thanks it sat in berryman's for a couple weeks and then I sprayed it out then I sprayed it all out again when I started the assembly.
Nj732port said:don't worry I used a mixture of sand and grease and lubed every passage possible right after I took all the pics! ;D![]()
it was running rich and hard to start before I tore it apart and I don't have any test riding in the near future so I want to get this thing squared away.
dualero said:Why don't you make some cardboard templates from the loop in order to have the pieces welded look good.
Instead of welding a big ass piece that don't match and then trim it
Sent from my GT-I9300 using Tapatalk
treitz said:Saw all those bikes at the 1 moto show last weekend. Some real good ones. Color is so much based on personal preference it's hard to make suggestions. What are you leaning towards?
Tune-A-Fish said:Red and Blue with white ;D
Tune-A-Fish said:I see the welding issue (maybe) I have that same welder, get the Argon bottle as soon as you can, but for now crank it up to one notch below full power, set the wire speed two down from fastest setting. when the welder is cold, always cut a fresh start in the flux core wire about 3/16 to 1/4" from tip keep the wire as close to the weld pool as that 1/2" as you can and stir the wire in the weld pool just a little, I go in counter clockwise motion... Get some scrap and practice, then get some tube and practice with that. You can also buy a jar of anti spatter or spay can to keep the bb's off.
Same welder same sheet metal, with gas.
