The sealing taper is the black rubber conical piece on the float valve - if it has any cuts / grooves / rings around it they may not seal properly.
The brass seat that the float valve goes into is pressed in. It has an o-ring that seats it into the carb body. You'll need to squirt some WD40 between the seat and the carb body and carefully pull the seat out. If that o-ring is broken or damaged fuel goes past it and straight into the carb bowl bypassing the float valve.
