Oh Lord (CB500) - The Leaky Bitch (p. 31)
Re: Oh Lord (CB500) - 07/01/2012 Battery Cable Question (pg. 26)
Use either a cheap jumper lead or lightweight welding cable.
I think it's about 8 gauge for original battery lead
Guys are using 8ga wire to upgrade the starter circuits on Ducati superbikes. I'm guessing if that works for a high compression 1000cc twin it'll work fine for a CB550... ;-)
I think that 8ga. is stock on these bikes. I keep 4 ga. in stock. If you want something lighter than that I can get it just let me know.
Arghhh!!! I'm so close!!!
So I've put power to the bike, and the headlight works, the oil preasure light works, the neutral light works, and the starter works! I washed the inside of the tank in preperation for coating it with the Caswell gas tank liner. I also finished up the rear brake linkage. I put 115 jets in it, and then I got stuck.
The damn float bowl gaskets are a pain in the ass to get on, so the carbs are sitting on the bench.
I've never torn into carbs on a 550 before. Does it have the rubber o-ring type gaskets or the older paper type ones?
Yeah, its got the rubber o-ring style. Booooo!
Yeah, sometimes those can be a pain in the ass to get into their little groove and stay there while you tighten everything down. Is that the problem you're having?
Thats exactly the issue. I've heard people say use some grease, liquid gasket, or super glue (lightly in the corners) to hold the gasket in place. But I've heard others say not to do that because it will disolve in the gas and clog up your carbs...
I haven't found super glue to be much use, silicon is just nasty when it reacts with gas.
I use a tiny dot of 'Shoe Goo' in the cornersand hold rubber in place until it holds in place.
The main problem is the 'O' rings supplied in aftermarket kits are the wrong size, the correct ones fit and hold without any problem or glue, etc
Any negatives to using a small dab of axle grease? Would that dissolving in gas be bad? Or would it thin out and burn up with combustion?
Re: Oh Lord (CB500) - float bowl gasket conversation...(pg. 27/28)
I don't know if axle grease would have enough 'stick' to hold?
It shouldn't cause any other problems unless it had a high metallic content that could build up on spark plugs (you would have to be pumping grease into fuel tank for that to be an issue)
I've used elmers white glue in the corners. a TINY amount. Works fine and never had an issue with it clogging carbs. I've had the thought about heating them in the carb bowl to get them to fit the shape, but have yet to try it. I suppose it would work.
Tomorrow, I will attempt to start it!
Re: Oh Lord (CB500) - Done! (?) (pg. 28)
And what about the rear? Those stacks are just gonna funnel everything right into your motor.
The yosh replicas are from motowerks go. The velocity stacks have a fine mesh screen in em, and I'm ordering some foam covers for em.
You'll be far better off fitting rear mudguard.
The mesh does nothing to stop engine damage/wear but it does restrict flow a significant amount (around 40~50%)
Putting foam over it will restrict airflow even more
mate that looks awesome well done!! you should be heaps proud. you will have to put a vid up as im crazy keen to hear her turn over
