"Patina" The 1973 CB175 Cafe Racer
and there is no seals used on the crankshaft the crankshaft is all roller and ball bearings there is almost zero way to fuck that up
my guess is camshaft endplay or pistons crazy tight
So here's the situation, I took the bike back to the guy who assembled my engine because when I was standing on it, the kicker wouldn't go down. Assuming something wasn't blocking rotation, that to me meant it was tight.
I took it down to him and said something was up with it and he took a look, found that the clutch wasn't adjusted properly and was able to depress the kicker. Once we got the kick gear turning the transmission, we could kick the bike over and the pistons only rose maybe a half inch per kick. The rest of it was play in the clutch slipping from what I gathered.
So my, and our, judgement is that it's too tight. Seems like it's something up top since the kick gear is meshing with the transmission and turning the crank. Or it was before it snapped off. Camshaft friction on the rappers sounds like a culprit but we will see.
I guess I feel bad and weird going to him telling him what to check. He's the mechanic. And I don't want to go to someone else become if something's wrong he should fix it.
Sorry, a rant. No need to respond to all that personal stuff :)
it is not camshaft friction on the rockers the only thing that would cause that is aftermarket springs and coilbind, do the checks I outlined above
Thanks XB.
Hey Matt,
Let's say we could eliminate the top end from the situation. After that, is there a way for the bottom end to bind at all? Because of the journals the shafts are resting in, the kind of find their "home" right? The transmission shifts great through all gears.
did you not say that you were able to turn the engine over with a wrench on the stator bolt ?
the guy that worked on it should have never turned it back over to you if it did not turn over and over and over, freely as it should
no there really is no way for the crank to be the issue you literally have to absoloutelly not know what you are doing to get that wrong
I guess it depends on your definition of "bind". From what I gathered, you're able to rotate everything, correct? It's just tight? Is it tight all the time or does it get easier and then harder and then easier again while you're rotating?
There's not a lot to check on the bottom end... If you get the head off, you're looking at piston-to-cylinder clearance issues, con rod bearings, or crank bearings. There are possible issues between the crank and primary, too.
Yessir, sure did. Sonreir said to start at the top and work down. Which jives with what you said.
I was just curious what he was referring to on the bottom end of things.
well you must eliminate the if the camshaft endplay is tight
it is the one thing that will cause a binding tight situation up top
It's probably going to be something related to the bottom end. Top end issues usually involve rocker arms, which because of their reciprocating nature, don't usually cause constant interference.
That's just where the quill goes through the head?
the #12 screws loosen each one a full turn
go over to the points side and with a block of wood smack the end of the cam bolt medium gently,straight through towards the other side not at an angle
then try rotation
http://www.bikebandit.com/houseofmotorcycles/1972-honda-cb175k6/o/m9196#sch396300
then try rotation
Perfect! Will do.
camshaft endplay too tight less than zero will do exactly what he describes
I ran back a couple of pages, but I'm not sure I read it correctly. Did you say that the motor turns over easily using a wrench or socket on the crank, but not if you try to turn it through the kicker or by rotating the back wheel?
If that's the case, then the issue is in the bottom end - either in the gearbox or the kickstarter arrangement.
If it doesn't turn easily with a wrench it could be anywhere in the motor. It is easy to assemble the bottom end with one of the main bearings out of position so that a locating pin is compressed. Your "mechanic" needs to be replaced though.
Hey Teazer,
If intake the stator cover off, the engine turns freely. I suppose the issue is that I don't know how "free" it should be. My estimate is somewhere between 30-40 ft-lbs to move it, with constant pressure and no fluctuation in tension.
The pistons were provided when the sleeves were bored for proper measuring. The rigs went in without a hitch. According to him, nothing really presented a problem. The valve train has not been touched for the most part.
One question, if I try to bump start when things are tight, am
I liable to hurt anything? A stupid answer can be provided for a stupid question :)
30 - 40 ft pounds of constant torque sound too high to me. You should feel it get harder when the valves open and almost run away from you as the valves close.
The question now is top middle or bottom. XB suggested loosening up the cam tower screws to see if that makes any difference. I would try that first. That will determine if there is too much tension on the came which would suggest a misisng gasket.
XB also suggested loosening the cam chain tensioner. That's a good idea, but that's almost impossible without removing the head because of the design.
It is possible to remove the engine top cover to get to the cam and see there's anything visibly wrong. With the cam tower screws (#12) loosened a turn or two, use a wrench or screwdriver on the cam sprocket to feel if it rotates in either direction. Careful that you don't mark the top gasket surface.
If that doesn't reveal anything I would be tempted to remove the cam chain and determine whether the problem is still there in the bottom or pistons or if it's in the head (ie the cam).
It could also be the oil pump . That sounds odd, but it's possible to bend the actuating/connecting rod. Before you pull the top end off, remove the clutch cover and see what you can see. Loosen the two oil pump mounting bolts and see if the bottom end now turns easier or if it tries to move the pump up or down hard as the motor rotates.
Did you paint the engine before sending it to the mechanic? I was trying to decipher that from the thread and your photos...
Looking at your Photobucket photos I don't see any gaskets between the cam holders or the top engine cover.
http://i904.photobucket.com/albums/ac250/greyrogers/PhotoNov1530457PM_zpsf3e54dee.jpg
If you look at the photos of when you got the engine (page 1) you can see that they stick out a bit towards the rear.
I suppose they could be a different color. They certainty aren't the same color as the green base gasket.
I'm not convinced there is one for the top engine cover either.
If you painted it after, then that would explain the hard to see gasket.
^***first timer he needs to be replaced with you...if we can do it anybody can do it!
