xb33bsa said:wow ;D that is good news
who was that that kept harping on about the cam hmmmmmm ? 8)
ding ding ding give this man a prize but i remember somebody saying to use a hammer?xb33bsa said:wow ;D that is good news
Texasstar said:
Texasstar said:The resistance through the coil should be 5ohms and through the plug holes 14
teazer said:And let us not forget that a fatter bluer spark is a sure sign of more spark energy and that means it also uses more battery or generator energy, so make sure that the battery is well charged and stays that way.
You will need new wires. The dyna had plug in style coil wires. I got the coil and 7mm wires off eBay as a kit. Tex runs 8mm. They are solid copper wires. I bought 5 ohm NGk spark plug boot.1sttimer said:Yeah, I noticed the connections are different for sure. On that front (and I'll check with Sonreir) I think it's just a matter of changing out bullet connectors for ring terminals...
On your other point, you're saying that leads are usually sealed to the coil body itself? Or epoxied to the plugs on the other end of the connector?
