"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
1sttimer said:
Nah, this one is double sided. There are single sided ones though. That's why if this thing actually works, it would be glorious.
Sweet then! You fingered it out.
Everytime I order something online I tell my wife I finger banged it.
Yeah, they're a bit pricey for what they are so I was just wondering if someone has used one.
I have used them before they work great might lose a drop or two when you disconnect them but way better then the alternative. You should be able to find them cheaper I would think.
Quick google search showed Rockymountain ATV has them for $10.
http://www.rockymountainatvmc.com/p/2989/-/212331/Tusk-Fuel-Line-Quick-Connect?ref=gmc&gclid=CIzU7qqswr0CFUqUfgodNKcAMw
Thanks man. I could find the single sided ones cheaper but the double sided are about twice the price.
I gotcha not sure if the one in the link I sent you is single or double. The ones I used look the ones for DCC. I worked at a aftermarket motorcycle gas tank company for about 6 months we used those for some of the tanks.
I have the double sided on both my 175 and 350. I will probably put them on every bike with a crossover line I ever have because it makes it so much easier to remove the tank!
That makes me feel better about that purchase I made from DCC with your paypal money about 20 minutes ago :D
In one pocket right out the other.
1sttimer said:
Saw one of these puppies rolling down the road today...
I saw the same guy at the same spot today. He was staring right at me as I snapped a picture of his bike. Haha.
cafe mike said:
Just a matter of cutting off the old leads and putting ring terminals on. Doesn't matter what's positive or neg even though it comes with a diag
Ok so I'm limited on wire length from my harness and EI to where I had to mount my coil...just to confirm, I can flip flop the connections on the positive to negative side of the coil without effect?
That is correct
I don't know how to upload photos on message.
Yeah the rib part you crimp. Not the smooth part
Ah got it. Good thing I only have two left after jacking it up. I'm glad they sent extras.
Ha! That was to make the dimple in the conductor so I could screw the resistor cap on.
New conundrum. Ive got full battery power, power to the EI, I have proper resistance across the coil body (~ 16.45) but no resistance across the resistance caps. If I take the caps off and shove the test leads right into the copper, I get equal resistance to what I was reading across the coil, which makes sense.
I've tried and tried to get the screw on the resistor cap threaded into the copper. Is there any trick to that??
If I read the resistance across the cap alone I get about 5 for each so they seem fine. It's almost like I'm just not making connection from the cap to the wire...
Here's across the coil or across the wires without caps.
Here's where I had to mount her. Had to drill an extra hole.
