"Patina" The 1973 CB175 Cafe Racer
cafe mike said:
Just a matter of cutting off the old leads and putting ring terminals on. Doesn't matter what's positive or neg even though it comes with a diag
Thanks, I thought I remembered reading somewhere you can swap the poles without effect. Thanks for confirming that :)
Normally, coils are polarity dependent and that's so that the spark travels in one direction. A twin lead coil sparks out of both end of the coil - so to speak and as such there's no polarity issues on the 12v side. At least that's how I understand it.
I finally went and picked up my bike today and it feels so wonderful just to have her home.
Took care of a few things. Traded the velocity stacks for UNI filters temporarily. It's just for protection while I troubleshoot and get it running at least. I need to order a new set of stacks that will give me enough room for a filter at the end.
I also took a terrible picture of the black powder coated heat shields but they look sweet paired with the black cylinder head.
Q: IS that battery rubber mounted or is it sitting on steel? I can't tell from the picture. Batteries have to be insulated from vibration. If they get the vibes, the plates start to break.
Hey Teazer,
The battery is sitting on top of hook and loop Velcro, so I'm guessing there's about 3/16" buffer between the steel and battery. This sufficient you think?
woops, good I have a spare one laying around for when mine dies ;D
Played with some wiring tonight. Here's a shoutout to Sonreir's handiwork. Few shots of the gauge lights, tail and headlight:
Also snagged this guy from a forum member. This will have to go on when I get tired of pushing the thing.
I ALMOST had a spare engine shipped to my door for $110 because the guy on ebay flubbed up the shipping estimate. He had the reserve at $85 and the shipping at $25 haha. Someone sniped me with a few minutes to go while I was asleep. I thought it was in the bag...:(
Highwind said:
I guess you cant run K&N filters instead of the UNI?
At my first glance at their measurements, no...
I went with uni for the time being because they are compressible and conform to the frame tube that they are pressed against.
As I mentioned above, this should be only temporary. I'm going to look into getting a piece of radiator hose that will get me beyond the frame tube interference and then use a velocity stack with exterior filter.
I have no idea how this is going to turn out, but I've spent $25 on everything so if it turns out halfway decent I'll be happy.
Yoga mat, rivet gun and rivets, washers to increase the surface area of the rivet cap, spray adhesive and black alligator skin vinyl.
Hey guys, hope this is a super simple question but am I correct in saying that the arrow on the end of the crankshaft is the direction of rotation? When I turn the crank in that direction everything is loose as a goose. When I turn it the other way, it's loose and then hits a stop of some sort. That would be preventing the engine from spinning backward?
Nothing should. It's not a grand idea to rotate is backwards (I think it's cam chain related), but nothing should technically stop it from rotating.
Gator skin is an interesting choice. I'm curious to see how it turns out. Post some pictures of the process too if you can. Upholstery is definitely a skill I need help with.
Yeah I have no idea what I'm doing. I'm not going the sewing route so I'll just be stretching and riveting.
Vinyl should be easy to work with. Should stretch three directions. I have never used that spray glue before, if it's anything like the 3m I use (has a adjustable low medium high pattern with rotating tip) and sprays cob web like pattern. Make sure you spray both sides and let tack.
Are you gonna have some kinda spreader (like flat stock) to rivet down. I would be afraid of the material ripping on rivet alone.
And last good luck. Use a heat gun to soften
Very good notes. I didn't even think about using a heat gun (or my fiancé's hair dryer :) ).
As if now I'm not going to use a piece of stock. I'm going to use some fairly meaty rivets (3/16") and attempt to double up the thickness of the vinyl at the rivet.
I'm going to try it without it and if I feel like it's not going to hold, I'll have to drill it out and try something else. I bought enough fabric for three tries or so. The way I see it, I can buy the lot of materials 8 times over and still save money over paying someone to do it. So I have some room for experimentation :)
Well, this turned out a lot better than expected....
Started out JB Welding the screws to the pan so I could screw the pan to the seat from the underside without them spinning.
Then I cut holes in the 1st layer of foam so the heads wouldn't cause the foam pad to have bumps where the screw heads are.
Then I drilled my holes for the rivets after taping the edges of the steel with painters tape so the vinyl won't get cut by the edge when I wrap it.
Then I started laying the foam down with spray adhesive one layer at a time. I put three layers on there and the thickness was perfect at that point.
Then I just started wrapping. I started from the straight sections and worked my way to the corners keeping everything right and tight. I didn't need a heat gun because it was quite stretchy. The up kick at the back was easier than I thought because the radius was large. The key is to move from one side to the other with each rivet so the vinyl gets pulled evenly from side to side. I checked the front often for wrinkles so I could be sure I had play to pull them flat.
Then I trimmed the excess. I'll just tuck what's left under and bolt it down.
And here's the finished product. I have to say, I couldn't be more pleased for only spending $24 and a total of 3 hours (including the half hour where I got a rivet stuck in the fun and had to take it apart :) )
