"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
I was thinking the yellow is carrying power to the coil. The red has to plug in to the EI unit. There's an 8 pin connector there that came with the unit. There is only one way to connect that.
That one has to be right.
See power from the switch is going to the 8 pin connector. The green goes off to the frame and the yellow goes off to coil.
Texasstar said:
Where is the yellow wire going?
Yellow to coil. Per instructions with EI and confirmed by Sonreir.
Seems to me that that one should have power when the switch is on. It doesn't light up.
Our power is coming from our switch to the left side of you coil then the right side goes to the electronic ignition plate that replace the points plate. There is a power wire that powers the electronic ignition wired into downside of the kill switch. The right side of the coil goes to what replaced your points plate the wire that went to your condenser
So you're saying I need a power wire from my switch to the coil? If that's the case what does the yellow wire do? I would have thought that's just a continuation of the power wire coming from the switch.
Also where is your kill wire?
this is our dyna s one wire goes to the rights side of the coil and the other wire is the power wire that is spiced into the downside of you handlebar or key switch
Was this the way it was wired to your other coil?
Where is that black and white wire at the top of your coil
This black and white it was at the top our your old coil going into the right side of the coil
