Texasstar said:You have the yellow wired into the wrong side it goes on the right of the dyna
Texasstar said:You are missing power to the left side of you coil where you have the yellow wire in your picture
Texasstar said:We are going to connect the power wire to the left side of the coil which is the positive side and the yellow wire to the negative side. Let me pull a dyna diagram to put you at ease
Texasstar said:
yes1sttimer said:The red power wire from the switch is going to that 8 pin connector in the EI. It terminates there. The only wires I have at all related to the coil are the white kill and yellow EI. Sounds like I need a power from the switch to the coil.
Texasstar said:
Texasstar said:
