"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
1sttimer said:
Ok tested the white wire and the light is coming on when the ignition is on and it goes off when the ignition switch is turned off.
White wire on the left side and yellow on the right.
Fire it up!!!!
Guess who just got a big blue fat spark from the wire? Wire alone but still.
You are golden now we should have power to the left side of the coil
You are the man. Throw them caps on and hold a plug on cyl like the second you tube video I posted....
Just a little tidbit. Bad Spark plugs will sometimes air gap spark when testing. But will not fire when under compression. I learned that at a young age owning two strokes. Weird for sure.
I don't have any gas or fuel line!!! My fuel line is coming in the mail tomorrow so I'll have to start it up after work :(
So one plug is sparking harder than the other. Any thoughts there? Both are brand new.
Well I guess I said that wrong . One lead is firing harder than the other. I used the same plug.
Are you grounding the plug the same way. And kicking it same speed
Congratulations you have been baptized in the 1st church of the electrons! Check your gap and connections!
Switch the wires and check then. Are your wires same length like I suggested. Even though it shouldn't matter that much
No kick. Bump only right now because my jagoff mechanic left out a gasket on the top end, had some camshaft end play and kicked over under binding and sheared the kick shaft off. I'm going to try to get along the summer bump starting and tear it back down this winter for a kicker.
I'm Turing over by hand.
I had to learn the hard way. But I learned a lot in school for residential and a&p school. I wish I would have had help like all of you guys. Bravo for all those who helped.
Don't over analyze it. Until you get your fuel line and run it. As long as your connections are good ( and you know they are you tested them) but you did it. One step closer. Now go have a beer
Mike, you said it before I could. You guys are incredible. I will indeed go have a beer, in front of this engine while I keep turning it over watching it spark ;) and while you cool guys are out actually riding their bikes!
In all seriousness, you guys deserve a round of applause. Thank you so much for another few hundred bucks saved by your advice. Cheers.
You will be in my new film, "men who stare at motorcycles"....for sure.
