"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
1sttimer said:
Hopefully the Guys help me remember but I don't recall measuring that one.
nope we didn't try that
Texasstar said:
I just realized why fluke voltage ohm meters are called fluke
Right. I have a fluke 88. Best meter!
a fluke will take care of a fluke ()
1sttimer said:
Mine is a Horror Freight version.
They can't even give those things away. Home Depot sells a nice auto ranging greenlee meter for 30$. Also is great is the royobi tek.
But throw that meter out!
Haha will do.
1sttimer said:
What result should that have yielded?
Hopefully a positive one. I recall reading somewhere that some coils use an isolated secondary.
Pic one is what I think we should have, but the second pic is what we might have.
Notice how the primary and secondary windings are joined in the first one, but not the second?
The second pic requires that the coil be grounded to the frame.
I called Larry at Dynatek and he said their coils are not polarity sensitive...the mystery continues.
Not strictly true, but in practice he's correct.
The polarity in which you wire your coils will determine whether the spark jumps from the center electrode to the side electrode, or the other way around. This matters because the center electrode runs hotter than the side electrode and electrons flow more easily from a hot medium to a cooler one.
But again, it's mostly academic as there is almost always enough voltage for things to work in either configuration.
why would you test new wires and caps anyway ? ::)
one huge issue is you are testing things that need not be tested and just cunfushion yourself
buttin it up goddamit giter done !
a test light was all you ever needed, we learned carry on
the second pix makes total sense...and xb33bsa...why? so we can go all macgyver if we need rewire a coil in the middle of the Sahara desert when we go the long and hard way around ;)
Matt,
Does the connection between coils represent the ability to flip the wires on the coil sides?
And if that's the case and we've seen signs if polarity sensitivity then do I need a ground?
The polarity conversation is academic. Ignore it for now. Just be mindful that the coil will work better in one direction than it will the other, but it should do the job in either direction.
Lol. I'm trying to get him to grab some go go juice and fuel line.
Let's do this thing..... And some clean undies
When I was younger I had a honda spree. And I raced my friends same exact scooter. And he beat me at a race. I dropped it on the ground. And it was so much faster. So every time I raced it I dropped it. I didn't question why. It just worked. Lol
Changed the float height every time :)
Couple questions about first start. Should I prime the cylinder somehow with a drop of gas or starter fluid or should a full tank with an open petcock be enough?
it should start on choke as per normal cold startup no priming should be needed
a good idea to verify oil to the top end once you start it
does it have a verification port like a 350 ?
there a few jokes that can cone from that question...as long as you have your bowls full you are good
we pulled our tappet covers just after first start.
