"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
Want me to tell you where on the crankshaft it sparks?
On top of the piston.... Mix some air.... Oh wait we need fuel...damn it batman
Fuel in the bowl, ignition on, tested for spark. Here we go.
Took three pushes, fired right up and went right to the redline. Air screw?
Are both slides working
What's your air screw adjusted at, from seat
Is air screw the protruding screw or the recessed screw.
I set both at 1.5 turns out
That's why! One is your air screw. The other adjusts the slide up and down. Back out the middle one!
Air screw is recessed
Middle one? There's only two.
cafe mike said:
Take off your filters and make sure your slides are going all the way down and up at the same time
Yeah checked that.
Yeah the one near the middle
cafe mike said:
Now as you back that off. Make sure it's dropping down and you don't have your cables too tight
One throttle cable end came out of the brass nipple and pulled the slide up. I screwed it all the way in, and they both rest at the same height.
Now how far do I back it out from bottom?
Did you turn the idle screw out yet?
