"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
There really isn't any difference in the chain slack as I rotate the wheel (that radial runout?). Are you saying there's an out-of-roundness effect going on with the sprocket?
I feel like if I had a .040" spacer between the sprocket and the circlip, it would knock it out.
Cush drive?
1sttimer said:
I am smoking a little bit, but I believe that's due to my rings not being seated yet. I think Texasstar had the same issue for a little while.
It was popping a little bit wanting to hesitate a little. Not sure what a miss feels like or sounds like but it was sputtering some.
Also, the vent comment is interesting. I have an ebay replica gas gap but I don't see how it could vent. The reason I say this is that I was able to turn the tank upside down and change out the petcock with gas in the tank without too much leaking beyond the cap.
we don't run the gasket on the tank cap for additional venting
Cush drive?
yes cush drive get the spacer warsher if it is constantly rattling around it will wear out the nose on the hub more quicker
this could cause the sprocket to be eratic radially
I just purchased that little ring from western hills honda. They called it a "dust plate" but he said it was about 1/16" thick...hopefully that works out. I'll update when it comes in. I may have a hard time letting that keep me off the bike....
Take a look at my build, I have photos. I cut the chain gaurd down so I didn't have that problem
Well I'm not charging anymore. Rode it all weekend and on the way home from the gym she started to lose power. I'm learning to recognize the symptoms now. The kill switch stopped working and then the lights dimmed and then lost power altogether except for the LED taillight.
In other news, I drew up some sweet headlight ears in CAD and had a very generous forum member HerrDeacon fabricate them. He did a freaking fantastic job. This should bring my light in a little closer.
In other good news realtions. My bike is getting loading inside of my trailer in the am. ,and getting hauled to my job tomorrow ( on my day off). I will me able to make the farkle parts for both our bikes!!!! We have a hot rod cruise in every month. On May 29 my bike ( horse with no name) will be unvaliled to the general public. I'm looking forward to the commentary. And hope fully future endeavors :)
Cool cool - I need the guard bad! I gotta clean the frame and engine every time I roll back in. Haha
On the cruise you gonna be able to keep up ;). What's your wife gonna ride? Drz?
Psssssst...... Real men grab the roll of Saran Wrap and toss on a couple of revolutions
Nah, the baking of the paint at first startup smelled bad enough
I meant it's a cruise in. It starts at 6, but some grab spots at 3.
Can you guys give me some insight into oil coming out of the cylinder head breather? How much is acceptable, how much is too much? I'm seeing a 3-4 drops every time I ride the bike.
The way my seat is mounted is freaking stupid. I'll probably end up redoing that. Cafe mike, this is why you are taking your time.
i wouldn't worry about it
you can put on a small can or bottle to catch the drips,for roadracing that is mandatory
https://www.google.com/search?q=breather+catch+can&rlz=1C1FLDB_enUS525US525&tbm=isch&tbo=u&source=univ&sa=X&ei=ZgaFU5XpMc32oATBqYGABA&ved=0CFQQsAQ&biw=1163&bih=606#q=breather+catch+can+motorcycle&tbm=isch&facrc=_&imgdii=_&imgrc=khkAKqqN8a3IEM%253A%3BFccjBmGV3z2JaM%3Bhttp%253A%252F%252Fi90.photobucket.com%252Falbums%252Fk248%252Fgalahs%252Fgs500f%252Fdiy_catch_bottle.jpg%3Bhttp%253A%252F%252Fwww.gixxer.com%252Fforums%252Fshowthread.php%253Ft%253D5419%3B600%3B600
the baffeling in the valve cover is supposed to reduce any excess i wonder if your builder put this together correctly ?
are you OVER filling the crankcase ?
