"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
Local dynojet guy quoted me between $400-$600 to tune her. Really?! How do people afford multiple trips??
Other guy about an hour away quoted between 2-300.
That's a bit high. I paid 200 for what seemed like half a day on the dyno to test three exhaust systems back to back and the dyno guy (owned the shop) helped me to change pipes.
We used to take our CB160/175 racers to a local dyno with boxes of jets and it cost 200-300 by the time we made 3 or 4 changes in jets and maybe one or two timing changes.
We tried to avoid busy days like weekends and if we could do it in the off season pricing is usually better.
I gotcha. It seems like these guys are used to bikes where the carb is not very accessible.
Luckily for me Tex knocked out 99% of the work. Got the exhaust I want (for now) and he passed along the tip of the 750 boots as stacks.
One good day of tuning should put me at a good spot for a daily rider.
Also that's assuming the new R/R solves my charging problem.
we pay 75 per hour but we got lucky ;)
We do our own tuning
Let's hope this does the trick :)
The little piece of steel I've been using for a "battery tray" has really been bothering me. I spent a lot of time on the bike as a whole, and that crappy piece wasn't doing t for me, even if it's hidden by the seat. So I took some dims and drew this up. I'll go the same approach of growing it to see if it fits, then sending the file to a machine shop to have them creat it out of sheet metal and weld it up.
Pissing out fuel from the overflow at a slight angle is bad float level right?
xb33bsa said:
was it doing that before ? sownds like the float neadle valve is leaking coold be fourin mattr
Ever since I took the carbs apart and put back together it has. Mainly the right carb and mainly when the tank is full.
well it is easy on you bike to drop the bowl if there is junk in the valve it should clear when you pull the float and needle
while you have the needle out look at it with a glass
if all looks good put back in and test it by hold very light pressure at the float with bowl off
Is that float pin a press fit? Can't seem to get that thing out. Without moving the float, actuation seems like it's working right, from my knowledge...
When the float rises, the pin is pressed and retracts up into the valve. When the float goes down, the pin falls out of the valve too. Nothin seems to be sticking.
Is it normal to have a dent in the float and a little gas in there? Not a lot
