"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
1sttimer said:
Small update...trying to get this thing on the road full time. Bought some CB750 intake boots to use as velocity stacks and covered them with a hacked up uni filter. Performance didn't change with and without the filter, so I feel good about that for some reason. Lots of flow, little restriction from the filter I guess.
you will like them!
Would these kind of filters essentially equal an open carb from a flow perspective? Theres no ram jet feature built in? Just an open pipe with a filter, no flange... hurt performance, increase protection?
http://www.ebay.com/itm/AIR-FILTER-45-DEGREE-TAPERED-CHROME-END-CAP-35mm-WILL-GO-33MM-TO-39MM-300021-/350706050500?pt=Motorcycles_Parts_Accessories&hash=item51a7b5a5c4&vxp=mtr
teazer said:
I'd look for a UNI filter that's big enough to fit over the velocity stack.
That's what I've got set up now :D cool. I was curious more than anything. I would t think those filters have any sort of ram jet built inside them.
FYI for the group the bike is off at a motorcycle drag shop getting the carbs dialed in. Video to come hopefully. If it stops pouring rain..
Do any of you guys run Optimol Racing Oils? Talked to a guy who swears by the stuff. Runs it in everything...in his car lasts about 11k before breaking down, then he takes it out and puts the used oil in his lawnmower.
I had SAE30 in my 175 which I guess was a big no no. I am seeing the value in little things make up big frictional losses. Maybe that's a big thing...
You can run an oil for a long time on a liquid cooled oil filtered automobile. It's probably not worth the money in something that's aircooled and doesn't have a paper oil filter. But Im no authority.
Check out bobistheoilguy.com...
The folks over there love empirical evidence.
we run amsoil 1040 synthetic
But don't run synthetic on break in
I've heard a rumor that running synthetic is bad for wet clutches (makes sense - lubricants). However Amsoil explicitly refuted that. No doubt you use it :D
"Many people have the perception that since synthetics are more slippery than petroleum oils (which simple don't reduce friction as well), that wet clutch packs in either their automotive automatic transmission or motorcycle transmission will slip when using "super slippery synthetics". AMSOIL Synthetic Oils are no more "slippery" than petroleum oil. AMSOIL Synthetic Oils simply have a more uniform molecular structure which reduces frictional resistance better than the irregular shape and size molecular structure of a petroleum oil.
Look at it this way. Wet sandpaper removes paint as well as dry sandpaper does. The slipperiness of the water does not impede the sandpaper's ability to function. The same applies to the "slipperiness" of synthetic lubes in wet clutches.
If used dry, the sandpaper is soon filled with paint and no longer works- it slips across the surface without grasping the surface. If kept clean and free of paint, it continues to work. The lubricating/cleaning solution used can be water, soap, oil or any other liquid. The liquid's slipperiness does not affect the performance of the sandpaper.
It is simply not an issue. However, just as rinsing the sandpaper keeps it cleaner longer so it functions better longer, so the AMSOIL Synthetic Oils keeps wet clutch plates cleaner longer so they function better.
AMSOIL Synthetic Oils will prevent deposit buildup on clutch plates, therefore keeping the face clean and able to do its job in preventing slippage.
And, since synthetics are superior cooling agents to conventional petroleum lubes, using synthetics will help wet clutches last longer, too.
Petroleum oils have low resistance to heat and allow varnish and glaze to form on clutch plates, which eventually leads to slippage and increased heat generation and eventually failure of the clutch pack."
Awesome website! I'll learn a lot there. He needs to brush up on his statistics though...you don't need 30 samples for significance :)
Hey guys, I opened a new thread for the CL200 engine rebuild I'm getting into. Hop on over and take a look. I'll need your help... :)
http://www.dotheton.com/forum/index.php?topic=61653.0
Update on the ole girl. Got the carbs jetted with the help of a local pro mod bike racing shop.
Took her down 3 sizes on the main jet and have her dialed in with the cb750 stacks and pre filter.
Took her top speed from 62 to 71 now. Idle is now around 1700 rpm.
Video to come soon.
What's "danger" zone RPM on these little guys in stock configuration? I know you can drastically alter with engine mods...but is the visual redline a good assumption?
Reason I ask is because I was pushing 8k going about 68-70 or so downhill and it felt like I had some more room, but the thing was screaming. Don't want to push it too far.
They are safe to around 10,500 but check the dyno chart to see where yours peaks. If it peaked at say 9500, then you probably want to gear it to make the most of what it has.
I've been trying to figure out how to get better charging out of patina. As it sits now, I can only ride about 20 miles until the voltage goes down on the battery and my lights begin to dim, then the bike eventually stops. It feel like it's running out of gas but it's not.
Been working with Matt and we both feel like it's my stator output. I am charging slightly but not close to where I should be.
So........
