"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
I have this cb350 twin motor stator laying around so I took the stator out of that.
Also the cover from the 350 fits but you need to flip it upside down and you need longer bolts.
I mocked up the 350 stator in the extra 200 motor before I tear the side cover off my only running bike.
It actually fits perfectly around the rotor but unfortunately the mounting method is different to mount the 350 stator to the 200 side cover. But it looks like all you have to do is drill out the case and the stator hole and tap it to accept an M8 instead of a M6 screw. And also change the round electrical plug to the square type.
Just remember to fit a Spark moto R/R and make sure you know where the timing mark used to be.
By the way thus is just an alternate solution to buying a Ricks stator
Tighter on cash right now so trying to see what I can do with what's laying around.
Trying to see if I can logic my way through my carb settings and need you guys' help. I recently went down three main jet sizes. Got me in the ballpark but now it seems like once the bike warms up, it runs a lot better mid throttle if I crack the choke.
I get a lot more power that way. So I'm thinking that's telling me I'm getting too much air, so in running lean. Going back up on the main jet one size could be a solution?
Are you choking the bike mid throttle?
What do your plugs look like?
I did both. Choked mid throttle and then choked the whole time. Choking the whole time only made a difference at mid throttle.
Deep chalky black. Smells strong of gas, not wet. Rich?
Did you oil your filters
Yeah I oiled my filters. Wonder what will happen if I yank the filters.
Rich is what the plug would have me believe, yea? But why is it that I get more mid range power choking? Seems counter intuitive. I guess plug color is key.
Mid-range power is controlled for the most part by the jet needle, you may need to move it down a notch (or shim it if there are no notches).
Ignore plug readings at mid throttle, they are grossly misleading.
What mains are in there now? Jet it right for WOT and if it's lumpy mid throttle, raise the needles 1 notch and then 2 notches and then try with the needles dropped one and then two notches and see what works best.
That's exactly what was done - good!. It pulls harder and stronger in 5th now but lost some mid range in the process.
I'll do exactly what you guys are recommending with the needle. Just so I understand the terminology, dropping the needle = raising the clip...
Thanks Perry. I'll do this.
Just looking back at my text and my wording may confuse a bit. By 'move it down a notch' I mean that the needle clip would be one notch lower (which raises the needle). I read teazer's response and realized how my wording may confuse so just wanted to clarify.
Here is a generic diagram to help.
